Multi-Notch Filter: Why 3 Not Working?
  • Thread starter Thread starter m718
    Filter
The discussion centers on the issue of using multiple 60Hz notch filters in a circuit, specifically why only the first filter functions effectively when three are connected in series. Each filter provides 12 dB attenuation individually, but the cumulative effect is not achieved due to load problems. The participants emphasize the significance of load considerations in filter design, particularly how the output of the first filter interacts with the input of the second filter.
  • Understanding of filter design principles
  • Knowledge of load impedance in electronic circuits
  • Familiarity with notch filter specifications and performance
  • Experience with circuit assembly and troubleshooting
  • Research the impact of load impedance on filter performance
  • Learn about cascading filters and their design considerations
  • Explore simulation tools for analyzing filter circuits
  • Investigate alternative filter designs for better performance
Electronics engineers, audio engineers, and hobbyists involved in circuit design and filter implementation will benefit from this discussion.
m718
how come more than one noth filter doesn't work. I Have three 60hz filters that have 12 db attenuation each when used one at a time but when I put them one after another in the circuit only the first works. all connections are proper I made the circuit many times because I thought I was doing somthing wrong.
Sounds like a load problem.
Load is an important factor in filter design, so you would need to consider how the input of the second filter looks to the output of the first one.
  • · Replies 29 ·
  • · Replies 51 ·
