Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Instantaneous Axis of Rotation Share It Thread Tools Search this Thread image
Old Jul14-04, 08:49 PM       Last edited by e(ho0n3; Jul14-04 at 08:50 PM.. Reason: spelling errors            #1
e(ho0n3
e(ho0n3 is Offline:
I have some doubts on the following:
When a wheel rolls without slipping, the point of contact of the wheel with the ground is instantaneously at rest. It is sometimes useful to think of the motion of the wheel as pure rotation about this "instantaneous axis". Points [on the wheel] close to the ground have a small linear speed, as they are close to this instantaneous axis, whereas points farther away have a greater linear speed.
The above is from my Giancoli physics book and accompanying the above is a picture of a bicycle wheel with the top part of the wheel blurred due to the greater speed. I understand what is happening here but I can't help to think that if all parts of the wheel aren't moving with the same speed then wouldn't the wheel suffer from some deformation? I'm guessing if the speed is relatively small, the deformation is ignorable.
Any comments?
Old Jul14-04, 09:05 PM                  #2
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
If all parts of the wheel aren't rotating with the same angular speed, then you'll have deformation. Perhaps that's what you are thinking of?
I don't see the problem with a rolling wheel. The linear velocity of any part with repect to the ground is the vector sum of its velocity with respect to the center (same speed for a given radius, but different directions!) plus the velocity of the center with respect to the ground (a constant, presumably). I'm sure you realize that the velocity w.r.t. the center of each part of the wheel points in a different direction.
Does that help at all?
Old Jul14-04, 09:40 PM                  #3
e(ho0n3
e(ho0n3 is Offline:
Yes, this is all perfectly clear.
Have you ever seen a drag race? When the light turns green and the drag racer accelerates, you can see that the wheels aquire an elliptical shape. But I guess this occurs because the wheels are slipping. I guess I'm misinterpreting the cause of the blur on the picture of the bike wheel.
Thanks
Old Jul15-04, 03:19 PM                  #4
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Ah... now I think I see what you are talking about. For the car to accelerate, frictional force must be exerted on the tire (and, vice versa, on the road). There is no way to do this without some distortion of the tire. (Good observation.)
But I don't think that has anything to do with the picture in your book, which I'm sure just shows a wheel rolling without slipping. Once it's up to speed, no further frictional force is needed (ideal case, of course). The top is probably blurred just to give you the feel that it's moving with respect to the ground (and the observer), while the bottom is unblurred because it's not moving. Makes sense to me.
image image
Reply
Thread Tools
Similar Threads for: Instantaneous Axis of Rotation
Thread Thread Starter Forum Replies Last Post
Can anyone PLEASE explain axis rotation? m0nk3y Classical Physics 2 Jan16-08 04:04 PM
Rotation about axis in R3 teleport Calculus & Beyond 9 Jul11-07 03:06 PM
Rotation about a fixed Axis rage_pandora Introductory Physics 6 Nov8-06 02:54 PM
Instantaneous centres of rotation Fermat General Engineering 2 Oct14-06 07:06 AM
help with rotation about a fixed axis alexhavak Introductory Physics 2 Nov7-05 12:54 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
