New Reply
String on Elastic Foundation
Share Thread Thread Tools
Nov1-09, 08:45 AM   #1
Consider a string on elastic foundations as shown in the following figure:
[IMG][/IMG]
The Strong form is given by
[IMG][/IMG]
Where U(x) is the transverse displacement, p(x) is the stiffness of the elastic foundation, T is the tension in the string and f(x) is the distributed load. The string is fixed at both ends.
Questions
1) a. Write the weak form obtained from the Strong form.
b. Write the minimum principle describing the problem.
2) a. Using Galerkin’s method, formulate the corresponding problem
( Kd=F) and describe the properties of K.
Hint: In your formulations, the term p(x)u(x) should be the part of stiffness matrix
b. Show that a similar system is obtained from the Rayleigh-Ritz method, employing the functional given in 1b.
3) The string is discredited into elements of length he. Assuming linear shape functions and piece wise constant f(X) and p(x) in the elements ( i.e fe and pe are constant within the element e, Find the element stiffness matrix Ke and the element force matrix Fe. Use the natural coordinate system for this derivation.
Next, the following parameters are chosen: T =1, p(x)=1, f(x) =10, L=6
4) find the exact solution uexactto the problem.( solve the problem analytically)
5) Subdivide the string into 2, 3 and 5 equal length elements. Assemble the elements and write down the global K and F for each case. Solve the system of equations and find the approximate solution vector d (The assembly should be done manually, however you can use MATLAB to solve the algebraic system of equations).
6. Plot the exact solution versus the three approximated solutions in one figure (use different colors, legend, and axis labeling).
7. Plot the derivative of the exact solution versus the derivative of the three approximated solutions in one figure.
8. What are your conclusions from questions 6 and 7? explain.
9. Assuming p(x) = 0 (no elastic foundations) and the other parameters are unchanged. Find the exact solution uexact and repeat question 5. Compare the approximate solutions at element nodes with the exact solution – what do you get? explain. Repeat question 6 for this problem.
10- Assuming p(X) =105 ( Very stiff elastic foundation) and other parameters unchanged.Find the exact solution uexact and repeat question 5. Compare the approximate solutions at element nodes with the exact solution – what do you get? explain. Repeat question 6 for this problem.
2. Relevant equations
3. The attempt at a solution
Don't know how to solve this problem
If someone can solve these problems then please help me i have to submit this home work next Friday.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov8-11, 10:13 PM   #2
Any help on this problem would be greatly appreciated
Thanks,
Troubled Finite Elements Student
New Reply
Thread Tools
Similar Threads for: String on Elastic Foundation
Thread Forum Replies
Using WKB(J) method to obtain asymptotics for an elastic string? Differential Equations 10
Beam/plate on elastic foundation..? General Engineering 4
A beam/plate on elastic foundation..... Advanced Physics Homework 0
Elastic ball , Inextensible string !!!!!!!!! Introductory Physics Homework 3
Elastic String - help required Introductory Physics Homework 1
