Need Help Wiring a large LED to Run Off Batteries
This discussion focuses on powering a 13W Evolux SH LED array light bulb using battery sources for documentary filmmaking. The bulb operates on 90~277V AC, necessitating a power inverter for battery use. Users suggest utilizing D-Cell rechargeable batteries, with configurations of either 2 or 3 batteries (1.2V to 1.5V) to connect to a CREE XRE-LED module. Resources for purchasing inverters and batteries are provided, including links to BatteryMart and LEDSupply.
  • Understanding of LED power requirements and specifications
  • Familiarity with battery types, specifically D-Cell rechargeable batteries
  • Knowledge of power inverters and their applications
  • Basic wiring skills for connecting LED modules
  • Research the specifications and compatibility of D-Cell rechargeable batteries for LED applications
  • Learn about different types of power inverters and their efficiency ratings
  • Explore wiring techniques for connecting CREE XRE-LED modules to battery sources
  • Investigate alternative LED lighting solutions for battery-powered setups
Documentary filmmakers, lighting technicians, and DIY enthusiasts looking to create portable, battery-powered lighting solutions for filming.
taylorbrush
I'm a documentary filmmaker and I am trying to build battery powered china lantern using an 13w Evolux SH LED array light bulb (http://eartheasy.com/store/proddetail.php?prod=EvoLuxSH).
I'd like to use something like D-Cell rechargable batteries, possibly from a modified light bulb, although since this bulb is made for AC power, I may need some sort of power inverter. It accepts 90~277 V AC.
Does anyone have any ideas about powering this with batteries? The objective is to have it suspended from a cable attached to a pole raised in the air so that we can have light for the camera as we film. Battery powered so we don't have to worry about trailing an extention cord.
You would need an inverter.
Someone found this site in another thread a few weeks ago:
http://www.batterymart.com/p-acc-pi-75-75-watt-power-inverter.html
They have other inverters as well as batteries and battery chargers.
If you like the packaging and diffusive dome, you can buy it, strip out the PCB and directly wire to the CREE XRE-LED module using between 2 and 3 1.5V batteries (some 'fresh' alkalines are 1.5V, while fully charged NiMHs or NiCads are 1.2V--under no conditions should you exceed the 3.9V listed on the datasheet):
http://www.ledsupply.com/docs/cree-xre.pdf
Or you can just buy the module itself for slightly less and wire it up as suggested above.
EDIT: Clearly, you need an integer value of batteries! I meant to say either 2 or 3 of the 1.2 to 1.5V batteries you have.
19K
  • Poll Poll
12K
11K
83K
16K
