What happens when the field when it did the work?
  • Context: Graduate
  • Thread starter Thread starter Creativity
    Field Work
The discussion revolves around the behavior of an electric field after performing work, particularly in the context of electrons moving within that field. Participants explore concepts related to energy transfer, charge interactions, and the implications of field strength in various scenarios, including capacitors and molecular interactions.
  • Some participants question what happens to the electric field after it has done work, suggesting that if the charge has not reached the positive electrode, the field retains its strength.
  • Others propose that the total field weakens as the system approaches equilibrium, indicating that the external field cannot be separated from the total field generated by displaced charges.
  • One participant introduces a modified scenario where an electron interacts with a molecule, raising questions about the energy involved in breaking atomic bonds and the effects on field strength.
  • Another participant discusses the movement of image charges in a capacitor setup, noting that the energy stored in the capacitor decreases as electrons move from one plate to another.
  • Concerns are raised about what occurs when an electron is captured before reaching the positive electrode, suggesting that the field does not weaken despite repeated work being done.
  • A later reply questions the availability of electrons and how a large number of working electrons might influence the field and energy requirements, contrasting this with the behavior of a single electron.
Participants express differing views on the behavior of the electric field after work is done, with no consensus reached on whether the field strength remains unchanged or weakens over time. The discussion includes multiple competing perspectives and remains unresolved.
Participants reference various scenarios involving capacitors and molecular interactions, but the assumptions regarding charge availability and field behavior are not fully explored or agreed upon.
Creativity
I recently brake my brain on the following problem:-------------------------------------- (+)
H~> light
e |
In uniform electric field the free electron (or some ion) gets accelerated to the point that it smashes against the hydrogen atom on the way. Hydrogen emits light and the work done by the electric field get converted into light.
the question is:
what happens to the electric field after it did a work? obviously if the charge has not reached the positive electrode the field has the same strength as it had before and it is ready for unlimited cases as above. work has been done and who payed for it? not the field obviously?
Who ends up paying in this case is the fella who put the electron there in the first place.
The total field gets weakened anyway. So the total system goes to an equilibrium. It is not correct to separate the "extermal filed" from the total: the field equations contain all sources of field, including the dispalced charge.
I will change the situation a bit :) I understood that the electron came to the system and its negative charge weakens the positive electrode field.Now:--------------------------------- (+)
XY-> X + Y
e
In this case electron hits a molecule XY ,gets X knocked out and stays with X forming a neutral atom. Y is now neutral too because XY shared a single electron as an atomic bond.
Obviously energy was spent on destruction of the XY bond.
Electron comes with the wind :) so is it that:
1) effectively wind energy splits XY?
2) no change in the field strength occurs?
As an electron moves (accelerates) in an electric field between two electrodes (e.g., anode and cathode), image charges on the electrodes move from one electrode to the other via the external network and the power supply. Voltage times charge = work.
Bob S
@Bob
There is no negative electrode here and neither is positive plate connected to any external source. Consider it a charged plate capacitor after removing its negative plate from the system.
PS:Anyhow you have answered my other question i had in my mind :)
Anyone?
Creativity said:
@Bob
If there is an electric field, there have to be electric image charges (with rare exceptions) that create the field. Conventionally this is similar to a capacitor. If a capacitor C has charge +/- Q on its plates with separation d, then the voltage and field is V=Q/C, and E = V/d. When an electon moves from the neg plate to the pos plate, it reduces the charge on the capacitor, and reduces both the voltage and field. The energy stored in a capacitor is (1/2)C V2. The discussion of what is happening as the electron is moving in the field is a little more complicated.
Bob S
Bob, what happens on a normally connected capacitor was clear to me already. When there is a wire between electrodes i see no problem. Whenever an electron jumps from one electrode to the other one (surge) i also understand that positive and negative plates will loose a charge.
What i ask is what happens when electron gets captured on its way to the positive electrode, so it never has a chance to reduce its charge. Electrode is not connected to anything, just a charge is resting on it so it attracts electrons from the environment, speeding them up, but they always get caught on the way. So when there is an interaction that disappears at one moment, but the work done by field is dissipated. However apparently, the field is never getting weaker after it did some work unlimited number of times...
The best way to calculate what happens when a small charge q leaves one plate of a capacitor with charge Q and plate separation X is to consider the following situation:
One plate has charge Q-q on it . At a very close at distance x is an intermediate plate with charge -(Q-q) on one side and +Q on the other (net charge difference +q). The other plate of the main capacitor is a distance X-x away, and has charge -Q on it.
Calculate the total stored energy as the intermediate plate moves from on electrode to the other.
Bob S
Here is a hint: are there an unlimited number of electrons available to do work? How do you think a large number of those "working electrons" would affect the field and the initial energy required? What is the difference in principle between a large number of working electrons and a single electron?
  • · Replies 22 ·
  • · Replies 45 ·
11K
