If you mean by "running" load a linearly distributed force per unit length along the longitudinal axis of the beam, then, yes, you are correct, the answer is "No". A
free body diagram will show that the force is constant at any section between the fixed end and the applied point load. If the beam was vertical under its own weight only, with no applied point load, then in that case the force distribution along the length would be linear.
