Relative Velocity of running towards a mirror
The discussion revolves around the concept of relative velocity in the context of a person running towards a mirror and the perceived motion of their reflection. Participants explore the implications of this scenario from both a physical and conceptual standpoint, examining how reflections are perceived and whether they can be considered to move.
  • Some participants propose that the reflection does not move at all, viewing it as a stationary artifact of the mirror.
  • Others argue that the reflection appears to move towards the observer at twice the speed of the observer, suggesting a perceived velocity of 10 m/s when running at 5 m/s.
  • A participant questions whether the reflection moves at the same speed as the observer or if it can be considered to move at a different rate relative to the observer.
  • Some participants assert that while the image changes position as the observer moves, this should not be interpreted as actual movement, emphasizing that the image is a manipulation of light by a fixed object.
  • Another viewpoint suggests that the movement of the reflection can be understood through the behavior of photons, which travel from the object to the mirror and then to the observer's eye.
Participants express differing views on whether the reflection can be considered to move. While some agree that the reflection does not physically move, others maintain that it appears to move relative to the observer. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the complexity of defining movement in this context, with discussions involving geometric interpretations and the nature of light. There are unresolved assumptions regarding the definitions of motion and perception.
Mech-Master
If you are running towards a mirror at 5m/sec, at what speed is your reflection moving towards you?
Science news on Phys.org
Welcome to PF, Mech-Master.
Your reflection doesn't move at all. It's an artifact of the mirror, and hence is stationary.
At what speed is the reflection moving towards the mirror, and in which direction? (To be specific, suppose you are running towards the left.)
my reflection in the mirror will move towards me wouldn't it?(will move towards the mirror from the other side if you know what I mean haha)
i am not sure if it will move at the same speed (5m/sec)
or
if you run towards the mirror with the speed 5m/sec, your reflection runs towards the mirror at the same speed. However, Relative to you, you are stationary and the mirror is moving towards you at 5m/sec - so your reflection is moving towards you at 10 m/sec?I am not sure it's confusing
Okay, I got the meaning. Actually, I sort of assumed your meaning the first time, but went with the practical approach.
Your image will appear to approach at twice your speed—in this case, 10 m/s. In physical reality, it doesn't move at all. The easiest way to think of it is that as you take one step (let's say 1/2 metre) toward the mirror, your image seems to take one toward you at the same time. That gives an apparent distance closure of 1 metre.
Again, though, the image itself does not actually move forward or backward. The mirror is a fixed object, and the image is produced by it.
If you are 2 m in front of the mirror, your image is 2 m behind the mirror. If you are 1 m in front of the mirror, your image is 1 m behind the mirror. In either case you can locate it geometrically using the law of reflection of light rays and some ray tracing and simple geometry. These distances have real physical implications. If you use a camera with manual focusing to take a picture of your own image in the mirror, you need to set the focusing control for a distance of 4 m or 2 m respectively.
When you change position, your image changes position, which I would consider to be "moving."
You are far and away more educated than I, but I just can't agree with that. The image is merely a manipulation of light by a fixed object. Any 'movement' is essentially an illusion. Assuming that the mirror is incapable of motion, the image 'trapped within it' is equally motionless.
I'm not declaring that I'm correct, but that's the way that I see it. If you can clarify the situation, I'm always glad to be educated. (That might sound sarcastic, but that's not how it's intended.)
It's slightly abstract but I don't have a problem with the image being seen as a moving object, defined by the distance traveled by the individual photons on their journey from the object to your eye (with a bounce off the mirror somewhere along the journey… this would be at half distance for the case of your eyeball, and approx half distance for other parts of your body)
That's my point, Molydood. Thanks for clarifying what I was thinking. The incoming photons stop at the mirror, not behind it. The emitted photons that compose the reflection originate at the mirror, not behind it. Any forward or backward movement is on an atomic scale.
  • · Replies 19 ·
  • · Replies 35 ·
