Thread Closed
vacuum vessel / distiller correct wall thickness??
Share Thread Thread Tools
Nov3-09, 01:22 AM   #1
Hello!
I have a vacuum vessel / distiller type of vessel with following:-
Temperature inside the vessel max. 200°C [Celcius] and a
Vacuum at max. -80kPa = -0.8bar
Material: SS-304 = Stainless Steel
Volume = 0.654m³
My main question:
Will a 4.5mm wall thickness (SS-304) be sufficient enough?
If yes we will use as "dish ends" 2:1 Semi-ellipsoidal at 6mm THK (Thick) to compensate on the shrinkage on the dish end bend, which is about 18-20%.
OR
I have formuals for pressure vessels / dish ends only - could I use them as well and use 1 bar pressure - to be safe.
Best regards and thank you all already for your suggestions - formulas & help given.
Pantera
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Thread Closed
Thread Tools
Similar Threads for: vacuum vessel / distiller correct wall thickness??
Thread Forum Replies
Measuring the gas temperature inside a vessel on the outside of the vessel General Physics 2
Forces on a pressure vessel containing a vacuum General Engineering 4
Strength of test tube with respect to wall thickness General Engineering 0
Formula for allowable wall thickness Materials & Chemical Engineering 2
