SPHERICAL CAPACITOR - with two insulating shells
The discussion focuses on calculating the potential difference (V) between two metallic shells of a spherical capacitor composed of two insulating spherical shells with different dielectric constants (K1 and K2) and a vacuum gap. The user proposes treating the system as three capacitors in series, utilizing the formula 1/Ceq = 1/C1 + 1/C2 + 1/C3 to derive the equivalent capacitance. The user also explores the integration method for potential difference, indicating a complex relationship between the capacitance and the dielectric properties. The final expression for the equivalent capacitance (Ct) incorporates the dielectric constants and geometrical dimensions, confirming the necessity of these variables in the calculation.
  • Understanding of spherical capacitors and their configurations
  • Knowledge of dielectric constants and their effects on capacitance
  • Familiarity with the formula for capacitors in series
  • Basic calculus for evaluating integrals in electrical potential calculations
  • Study the derivation of capacitance for spherical capacitors with varying dielectric constants
  • Learn about the application of integrals in calculating electric potential in capacitive systems
  • Explore advanced capacitor configurations and their implications in circuit design
  • Investigate the impact of dielectric materials on the performance of capacitors
Electrical engineers, physics students, and anyone involved in capacitor design or analysis, particularly those working with complex dielectric materials and spherical geometries.
Grommit
PLEASE HELP ASAP - Spherical capacitor
I could really use some help with this one, and I need to submit very soon...
Problem:
A spherical capacitor is made of two insulating spherical shells with different dielectric
constants K1 and K2 situated between two (inner and outer, shown by thick lines)
spherical metallic shells and separated by a vacuum gap. Geometrical dimensions of
the cross-section are as shown in figure 2. Outer metallic shell has charge +Q and the
inner metallic shell has charge −Q. What is the potential difference V between these
metallic shells?
Image: http://tinyurl.com/yazcvq2
If I am understanding this correctly, this can be interpreted as three capacitors connected in series. To that end, I thought I could utilize the equation for capacitors in series: 1/Ceq = 1/C1 + 1/C2 +1/C3. Then, Ceq=Q/V would indicate the potential difference. (Im thinking this may be flawed logic though).
Using K*(4*pi*Epsilon(0))*(a*b)/(b-a) for the spherical capacitances seems to be making a cumbersome mess of numbers more than anything.
Im starting to think now that maybe I should be setting up an integral along the lines of V=Q/(4*pi*Epsilon(0)) INTEGRAL (from a to b) db/b^2... hope that makes sense.
Thanks in advance for any help.
FWIW, I found the problem partially worked out in this manner:
Basically you have 3 capacitors in series, the first has a dielectric K2 with a thickness b -a, the second has a vacuum dielectric with a thickness c-b and the third capacitor with a dielectric K3 with a thickness d -c.
C1 = K2/(b-a), C2 = 1/(c-b), and C3 = K1/(d-c)
1/Ct = 1/C1 + 1/C2 + 1/C3
1/Ct = (b-a)/K2 + (c-b) + (d-c)/K1
1/Ct = (K1(b-a) +K1(K2)(c-b) + K2(d-c))/K1(K2)
Ct = K1(K2)/(K1(b-a) +K1(K2)(c-b) + K2(d-c))
http://answers.yahoo.com/question/i...F112UmVhoyDA.YirA--&paid=add_comment#openions
However, this solution doesn't seem to have the variables for spherical capacitance included ==> K*(4*pi*Epsilon(0))*(a*b)/(b-a)
  • · Replies 23 ·
