Circuit with capacitor question
  • Thread starter Thread starter Timiop2008
    Capacitor Circuit
The discussion centers on a parallel circuit comprising a 4.5V cell, a 2200µF capacitor, and a 5.6kΩ resistor. The time constant (RC) is calculated as 12,320 seconds, derived from the formula T=RC, where R is the resistance and C is the capacitance. The initial discharge current is approximately 0.817mA, calculated using Ohm's law (I=V/R). For the current after RC seconds, the voltage decay is described by the equation V = V_0 * e^(-t/RC), which is essential for determining the current at that time.
  • Understanding of Ohm's Law
  • Knowledge of RC time constant in electrical circuits
  • Familiarity with capacitor discharge equations
  • Basic proficiency in exponential decay functions
  • Study the derivation and application of the RC time constant in circuits
  • Learn about capacitor discharge behavior and its mathematical modeling
  • Explore advanced circuit analysis techniques using differential equations
  • Investigate practical applications of capacitors in electronic devices
Electrical engineers, electronics students, and hobbyists interested in circuit design and analysis, particularly those focusing on capacitor behavior in parallel circuits.
Timiop2008
Hi Can anybody check the answers to this question?. I am not sure if they are correct. I would appreciate if anyone can help me with the last part, (c). Thanks
A Parallel Circuit contains three components attached in parallel a 4.5V Cell, a 2200uF Capacitor and a 5.6kΩ resistor. A switch in the circuit is moved into the on position so the capacitor discharges through the resistor.
a) What is the value of the Time Constant RC for this circuit?
Attempt:
T=RC
=5600X2.2
=12,320s
b) When the switch is turned on, show that initial discharge is about 0.8mA
Attempt:
1/RC
=1/12320
=8.17X10^-5 A
=0.817mA
c) Calculate the Current In the circuit after RC seconds
I do not really know how to do this question. Would you use I=Q/t ?
In (a), note that 2200uF = 2200*10^-6 F
In (b) you use 1/(RC) as if it is a current. Actually RC has units of seconds.
If the capacitor was initially charged to 4.5 Volts, then the initial current would be I = V/R = 4.5/5600.
If you just want the answer to (c), read the first sentence at
http://en.wikipedia.org/wiki/RC_time_constant
This is because the capacitor/resistor circuit voltage decays like
V = Vo*e^(-t/RC)
Attempt:
T=RC
=5600X2.2
=12,320s
No. The capacitance is in microfarads, not milli farads.
Attempt:
1/RC
=1/12320
=8.17X10^-5 A
=0.817mA
V = 4.5 volts. R = 5.6kohms. Use Ohms law to find the current.
Use:
[tex]V = V_0e^{-t/RC}[/tex]
When t = RC seconds, what is V?
Use Ohm's law to work out the current from this voltage.
AM
