A problem that i spotted about expansion;
  • Thread starter Thread starter Cryphonus
    Expansion
The discussion centers on the misunderstanding of the thermal expansion formula for solids, specifically the linear expansion of a metal stick. The correct formula for calculating the change in length due to temperature change is ΔL = L₀λΔT, where L₀ is the initial length, λ is the coefficient of thermal expansion, and ΔT is the change in temperature. The forum participants clarify that the formula L = L₀(1 + λΔT) should be used for accurate calculations, emphasizing that the expansion formula is valid only when λΔT remains small, typically when λ is significantly less than 1.
  • Understanding of thermal expansion concepts
  • Familiarity with the coefficient of thermal expansion (λ)
  • Basic algebra for manipulating equations
  • Knowledge of temperature measurement and units
  • Study the derivation and applications of the linear thermal expansion formula
  • Explore the implications of large values of λ in material science
  • Learn about the differences between linear and volumetric thermal expansion
  • Investigate real-world examples of thermal expansion in engineering applications
Students in physics or engineering, material scientists, and professionals involved in thermal management or structural engineering will benefit from this discussion.
Cryphonus
So this question was on my mind for about 2 years and since i discovered such a good forum i wanted to ask to get an answer;I asked this question to various instructors but couldn't get an answer unfortunately, so here it is
The formula to express the expansion for 1 dimension (for a metal stick for example) is:
L=L(initial).λ.Δt
So my problem is the formula itself;
Lets imagine a stick with 10 cm and the temperature of the stick is 10 unfortunately let's say; After that i decided to increase the temperature for 10 unfortunately more, so our temperature is 20 unfortunately and eventually our stick is going to expand a bit,
L=L(initial). λ.Δt
L initial(Lets take it 10 meters) So:
L(for 20 unfortunately)=10.λ(which is a constant doesn't matter in this case).10 (change in the temperature)
We calculated the new length of the stick no problem so far;
The temperature of the environment is 20 unfortunately at them moment; so i want to cool the air a little by bringing the temperature to 10 unfortunately again.If we calculate the new situation now;
L=L(the value for 20 unfortunately which is bigger than 10 meters for sure, let's take it 12 in that case).λ(constant doesn't matter).Δt (which is again 10)
so the value that we find is actually much bigger than the one for 10 unfortunately,since our L is bigger at 20 unfortunately ,our stick should be much more small then 10 meters which was our initial value,
If you try this you will also see that the stick will go to 0 if we keep changing the temperature to 10-20.If we do this infinite times our stick should be vanished according to the mathematical equation.
Waiting for your answers thanks a lot;
Your premise is wrong. This is not the formula for thermal expansion.
The change in length (not the full length) is a linear function of temperature change and initial length:
[tex]\Delta L = L_0\lambda\Delta t[/tex]
where [itex]\lambda[/itex] is the co-efficient of thermal expansion.
[tex]L = L_0(1 +\lambda\Delta t)[/tex]
AM
I think the OP is pointing out a problem with the linear expansion formula for large values of λ. For example, say λ = 0.05 and the rod starts out with a length L0 of 10 m.
For ΔT = +10 degrees, we have L1 = 10 + .05*10*10 = 15 m.
If we then cool it down by 10 degrees (to its original temperature), we get:
L'0 = 15 - .05*15*10 = 7.5m ... which is smaller than it started out!
The answer is that the expansion formula only makes sense when λ*ΔT is small enough. (Usually, λ << 1.)
  • · Replies 67 ·
