Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Excel projectile motion, help! Share It Thread Tools Search this Thread image
Old Nov4-09, 02:01 AM       Last edited by mysticjbyrd; Nov4-09 at 02:10 AM..            #1
mysticjbyrd
mysticjbyrd is Offline:
I am attempting to create an excel worksheet that accurately predicts the trajectory of a projectile.
Anyways, I am having some trouble with calculating wind along the Z axis, left or right of the target.
Y axis is up in the air
X axis is towards the target
Z axis is left or right of target
Fd = force of drag
Fw = force of wind
Fb = force applied on golf ball
p = Rho, density of air
Cd = Drag coefficient
V = velocity
A = Area, which for a sphere I am using A = PI(Diameter)^2 /4
m= mass of golf ball
a = acceleration of ball
t = time
z = distance off from z-axis
Force of wind(Fw) ->
<- Force of drag(Fd)
I am using,
Fd = 1/2*p*Cd*V^2*A
So,
Fw = 1/2*p*Cd*Vw^2*A
Vw = simply wind speed, Fw is constant
and
Fd = 1/2*p*Cd*Vd^2*A
Vd = Fw / mass * time
then
Fw - Fd = Fb
Fb = force applied on ball
Fb/mass = acceleration of ball
then
z = Vot + 1/2at^2
I am getting an acceleration that is roughly constant since I am dealing with low wind speeds and short time of flight. However, I am getting extremely low #'s for the distance the ball strays off on Z axis. I get the same answer if I use a constant acceleration or time stamps.
Information with just variables is fine with me, but if you want the data for some reason...
mass of golf ball = 0.04593
diameter of golf ball = 0.04267
Wind velocity = .44704 m/s
Rho = 1.1735 kg/m^3
Cd = .3878
time of flight = 1 sec
I am getting 0.0007221 meters off on z-axis.
Not sure where I am going wrong... Any help would be much appreciated.
Old Nov4-09, 02:45 AM                  #2
fatra2
fatra2 is Offline:
Re: Excel projectile motion, help!
Look here: http://www.physicsforums.com/showthread.php?t=351066
I just answered the same question to this dude.
Cheers
Old Nov4-09, 02:53 AM                  #3
willem2
willem2 is Offline:
Rho = 1.1735 kg/m^3
Cd = .3878
I'm getting 10 times that when I calculate it.
The way you calculate the drag and the force of the wind is wrong, you can't separate them
You need to add the vectors of the wind speed and the apparent wind because of the velocity of the ball, calculate the magnitude of the result, and calculate the total force from that, and then separate the force again in x, y and z components.
You'll get a much bigger force in the z direction that way. This is the same effect that makes cyclists feel more drag if there is a wind from the side.
Treating the drag force or the wind force as constant will only work if the velocity of the ball
changes little. Even in 1 second you get 10 m/s velocity change in the downward direction. This will have an influence on the windforce too. You really need to compute the solution of a set of differential equations for any realistic golfball trajectory. I suppose it can be done in excel with one row for each timestep.
Old Nov4-09, 03:11 AM                  #4
willem2
willem2 is Offline:
Cheers
You were too late. Also your method won't work if the drag force is proportional to the square of the velocity, because you no longer can compute the x and y components separately.
Old Nov4-09, 05:02 AM                  #5
fatra2
fatra2 is Offline:
In the case of a projectile thrown in the air, the drag force is linearly proportional to the velocity. Of course, you must consider that the air is homogenous.
Cheers
Old Nov4-09, 09:20 AM                  #6
willem2
willem2 is Offline:
It's only linear for small velocities. While mysticjbyrd doesn't give the ball velocity, he is using quadratic friction. Everything I can find about friction with golfball sized objects uses a
quadratic friction force, as did mysticjbyrd so I have to assume a quadratic friction force here.
Old Nov4-09, 10:04 AM       Last edited by mysticjbyrd; Nov4-09 at 12:42 PM..            #7
mysticjbyrd
Could you give me an example of what you did? I am still a little confused.
Old Nov4-09, 07:21 PM                  #8
willem2
willem2 is Offline:
suppose the ball is moving at 10 m/s, and you have 1 m/s wind from the side.
The speed of the ball relative to the air is LaTeX Code:  v = \\sqrt{v_{ball}^2+{v_wind}^2}  = 10.05 m/s
the friction force is (1/2)*C*A*v^2. The sideways component of this is (1/2)*C*A*v*v_wind
this more than 10 times as big as the force of the wind on a stationary ball
Old Nov5-09, 11:56 AM                  #9
mysticjbyrd
Ok so what you are saying is that you have to consider the velocity of the ball from both the X and Z.
But what about the velocity of the Y axis as the ball falls?
Sorry to be so annoying, I have only had 1 semester of physics thus far, and I appreciate the help.
Old Nov7-09, 02:57 PM                  #10
mysticjbyrd
can anyone else give me some more input? Thanks
Old Nov10-09, 05:20 PM                  #11
mysticjbyrd
You are using wind relative to the ground and not the ball... The ball wont be traveling anywhere near 1 m/s on z axis
Old T, 08:26 PM                  #12
mysticjbyrd
Old T, 09:37 PM                  #13
ideasrule
ideasrule is Offline:
If you're using small timesteps, the most naive possible algorithm works well; you don't need to use y=v0t+1/2gt^2. In each timestep, calculate:
1) acceleration (in x, y, z)
2) velocity
3) position
4) total drag force (remember to use the speed of the air as the ball sees it, not as the ground sees it)
5) components of drag force (you'll have to do some trigonometry for this one)
6) in the next time step acceleration will be calculated again
Also, golf balls usually have a time of flight much longer than one second.
image image
Reply
Thread Tools
Similar Threads for: Excel projectile motion, help!
Thread Thread Starter Forum Replies Last Post
Projectile Motion with Air Resistance Excel... EVIL... gMitchell Advanced Physics 7 Nov4-09 10:37 AM
Projectile Motion assignment - Building a projectile launcher Hans Introductory Physics 3 Oct21-09 04:59 PM
Motion Simulation using Graphing Technique in Microsoft Excel akedynamic Math & Science Software 0 Jun29-09 12:26 PM
Projectile Motion + Linear Motion = Problem ktd Introductory Physics 3 Feb21-05 08:04 PM
Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): VinnyCee Introductory Physics 4 Sep27-04 07:29 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
