Finding a spring constant of a spring holding a mass
The discussion focuses on determining the spring constant (k) for a spring attached to a vertical hoop, with a mass (m) dropped from the top. The spring force is defined as F = -kx + 2Rk, leading to a potential energy equation V(x) = 0.5kx² - 2Rkx + 2R²k. The energy equation combines kinetic and potential energy, expressed as E = 0.5mv² + V(x) + mgx. The solution suggests using the harmonic oscillation equation to define the spring constant k for regular motion.
  • Understanding of harmonic motion and oscillation principles
  • Familiarity with potential and kinetic energy equations
  • Knowledge of spring force calculations and Hooke's Law
  • Basic calculus for integrating force to find potential energy
  • Study the derivation of the harmonic oscillator equation
  • Learn about energy conservation in oscillatory systems
  • Explore advanced applications of Hooke's Law in real-world scenarios
  • Investigate the effects of damping on oscillatory motion
Students studying physics, particularly those focusing on mechanics and oscillations, as well as educators looking for practical examples of spring dynamics in motion.
boardbox
I have a vertical hoop of radius R. A spring with spring constant k and relaxed length 0 is attached to the top of the hoop. A block of mass m is attached to the spring and dropped. Assuming the motion is a linear vertical oscillation between the top and bottom of the hoop, what is k?
Spring force = -kx
Potential = -Integral(force) from a reference point to x
E = KE + PE
Set x = 0 to the bottom of the hoop and let x positive point up.
This gives me F = -kx + 2Rk for the force exerted by the spring on my mass.
This gives me a spring potential:
V(x) = .5kx2 - 2Rkx + 2R2k
Gives me energy:
E = .5mv2 + V(x) + mgx
I know that x(0) = 2R and v(0) = 0, so I have an initial energy in terms of known variables but I can't think of anything to compare it with. I've written out the equation of motion for the mass to try to find some other functional x(t), v(t) values, but I'd like to know if there's some simpler method of solution that I'm just missing.
Looking for a value for k.
Hi there,
If the block is going up and down in a regular motion, then you can define the k constant through the harmonic oscillation equation.
Cheers
  • · Replies 17 ·
  • · Replies 17 ·
