How Do You Calculate the Angle of Incline with Friction Involved?
  • Thread starter Thread starter db7db7
    Angle Incline
The discussion focuses on calculating the angle of incline when friction is involved, specifically for a body weighing 50N that requires a force of 35N to ascend the incline with a coefficient of friction of 0.25. The equation used is F = W sin a + u W cos a, leading to the equation 35N = 50N*sin a + 0.25*50N*cos a. Participants suggest using graphing techniques or spreadsheet formulas to isolate the angle "a" and recommend employing trigonometric identities and the unit circle for a more analytical approach to solve the problem.
  • Understanding of basic physics concepts such as weight, force, and friction.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Ability to manipulate algebraic equations and solve for variables.
  • Experience with graphing techniques or spreadsheet software for numerical solutions.
  • Learn how to graph trigonometric equations using graphing calculators or software.
  • Study the unit circle and its applications in solving trigonometric equations.
  • Explore methods for solving quadratic equations derived from trigonometric identities.
  • Investigate the principles of static and kinetic friction in inclined planes.
Students studying physics, particularly those focusing on mechanics and inclined planes, as well as educators seeking effective methods for teaching trigonometric applications in real-world scenarios.
db7db7
On a certain incline plane, a body weighs 50N and requires a force of 35N to pull it up the incline. If the coefficient of friction is 0.25, find the angle of incline. (in degrees)
I've been stuck on this for two days now.
F=W sin a + u W cos a
35N= 50N*sin a + 0.25*50N*cos a
I'm not sure how to isolate for "a".
I don't know how to isolate "a" either, but you can certainly find the answer to any desired accuracy. You could graph the y = 50N*sin a + 0.25*50N*cos a on your calculator and see where it intersects y = 35. Or put it in a spreadsheet formula and try various values for a until you get an answer of 35.
An interesting approach is to use the method of solving triq equations where you replace cos a with x and sin a with y. This gives a linear equation of the form y = mx + b which you can easily graph. Also graph the unit circle. The intersections of the line and circle are the x,y solutions and the angle counterclockwise from the x-axis is the solution for angle a. You can actually solve this without using the graph if you write x² + y² = 1 for the unit circle and then solve the two equations simultaneously (solve the linear one for y and sub into the circle equation). You end up with a quadratic equation that you can solve to get x and then use x = cos(a) to find the value of a.
12K
9K
