Proving the Limit of f(ax) with Delta Epsilon
The discussion focuses on proving the limit of the function f(ax) as x approaches 0, given that lim (x-->0) f(x) = L. The key insight is that for any epsilon > 0, a corresponding delta can be chosen such that if 0 < |ax| < |a|d1, then |f(ax) - L| < epsilon. The participants clarify that while the textbook states d2 = d1/|a|, it is essential to recognize that the continuity of f allows for the selection of delta based on the scaling factor a, thus ensuring the limit holds true.
  • Understanding of limits and continuity in calculus
  • Familiarity with the epsilon-delta definition of limits
  • Basic knowledge of function transformations
  • Experience with polynomial functions, specifically cubic functions like f(x) = x^3
  • Study the epsilon-delta definition of limits in more depth
  • Explore the properties of continuous functions and their implications on limits
  • Investigate function transformations and their effects on limits
  • Practice proving limits with various functions, focusing on scaling factors
Students of calculus, mathematics educators, and anyone looking to deepen their understanding of limits and continuity in mathematical analysis.
evry190
hey if lim (x-->0) f(x) = L
where 0 < |x| < d1 implies |f(x) - L | < e
how do i prove lim (x --> 0) f(ax) = L?
i know
0 < |ax| < |a|d1
d2 = |a|d1
but the textbook says d2 = d1/|a|
help you guyssssssssssssssssssssssssssssssss
You get to choose what d2 is
You know that the function f is continuous, so you know that given epsilon > 0, there exists an delta > 0 satisfying
d(x)<delta -> d(f(x),l))<epsilon. Now your problem asks you to show that, given an epsilon > 0, you can find a delta such that d(x)<delta -> d(f(ax),l)<epsilon.
The point is that, you can also choose such a delta for ax. the continuity of the f immediately tells you that you can choose such a delta. What if f were the function f(x) = x^3? consider a neighborhood of f(x)=l=0, (-8,8). Then if x is between -2,2, we know that this relation holds. However, f(ax), a = 5, gives us a drastically stretched function. (-8, 8) is stretched to (-40, 40). if x is between -2/5, 2/5 = original delta/a, then d (f(ax), l) < d(f(x),l)<epsilon, because d(x) is now less than the first delta (2) in this case (because f(ax), x<delta over a implies that x from our second delta neighborhood, times a, is in our first delta neighborhood Adapt, and you'll be done.
  • · Replies 31 ·
