A particle moving in an electromagnetic field
A charged particle with charge q and mass m moves in an electric field E = (0, E_0, 0) and a magnetic field B = (0, 0, B_0). The equations of motion derived are m x''[t] = B_0 q y'[t], m y''[t] = q (E_0 - B_0 x'[t]), and m z''[t] = 0. The solutions for position are x[t], y[t], and z[t], but the case where B_0 = 0 presents a challenge as it leads to a division by zero in the equations. The discussion highlights the use of crossed fields in applications like the Wein filter for particle beam manipulation and magnetron microwave tubes.
  • Understanding of classical mechanics, specifically Newton's laws of motion.
  • Familiarity with electromagnetic theory, particularly the Lorentz force law.
  • Proficiency in Mathematica for solving differential equations.
  • Knowledge of particle physics and beam dynamics.
  • Study the Lorentz force law in detail to understand its applications in charged particle motion.
  • Learn about the Wein filter and its role in particle beam manipulation.
  • Explore the use of Mathematica for solving differential equations in physics.
  • Investigate the implications of crossed electric and magnetic fields in various technologies, including magnetron microwave tubes.
Physicists, engineers, and students interested in electromagnetism, particle dynamics, and computational physics using Mathematica.
Barbara.Ba
Dear Friends
A particle having charge q and mass m moves in a region where
an electric field
E = ( 0 , E_0 , 0 )
and a magnetic one
B = ( 0 , 0 , B_0 )
exist.
For t = 0 its position is
R = ( 0 , 0 , 0 )
and its velocity is
V = ( V_0 , 0 , 0 ).
I have worked out the equations of motion
you can see them and their solution in a fine graphical form at
http://i786.photobucket.com/albums/yy150/simona1989_photo/img.jpg
In text only mode they are:
m x''[t]==B0 q y'[t]
m y''[t]==q (E0-B0 x'[t])
m z''[t]==0
x[t] = ( B0 E0 q t-m (E0-B0 V) Sin[(B0 q t)/m] ) / ( B_02 q)
y[t] = ( 2 m (E0-B0 V) Sin[(B0 q t)/(2 m)]2 ) / ( B_02 q )
z[t] = 0
but I get a strange and obviously wrong phenomenon in the solution:
they correctly give the solution of the case E_0 = 0 but they have no meaning for B_0 = 0 (because B_0 appears into denominator of solutions).
Please note that the equations of motions of the general case ( E_0 and B_0 both not zero ) reduces normally at the right equations of motions for E_0 = 0 and B_0 = 0.
Please can you suggest an hint for the reason of that, or the wrong step in my reasoning ?
If you feel confortable with Mathematica, may be you want see, at bottom of this message, the Mathematica code I have used to confirm my hand written solutions.
Thanks for your attention!
Warmest regards
Barbara.Ba
(* position at t *)
pos = {x[t], y[t], z[t]};
(* velociy' and acceleration t *)
vel = (D[#, {t, 1}]) & /@ pos;
ac = (D[#, {t, 2}]) & /@ pos;
(* the given fields *)
cE = {0, E0, 0};
cB = {0, 0, B0};
(* the Lorentz force for the given fields *)
F = q (cE + Cross[vel, cB]);
(* the equations of motions *)
eq = Table[m ac[[k]] == F[[k]], {k, 1, Length[ac]}];
(* position and velocity for t = 0 *)
cond = {x[0] == 0, y[0] == 0, z[0] == 0, x'[0] == V, y'[0] == 0, z'[0] == 0};
(* this solves the equations of motions *)
sol = DSolve[{eq, cond}, pos, t] // Simplify;
(* output *)
Print["\n\n--- equations of motions ---\n\n", eq // TableForm];
Print["\n\n--- solutions ---\n\n", Transpose[sol] // TableForm];
This is a good question. A crossed field (crossed dc E and B fields) is used to filter out charged particles with different velocities in a particle beam with defined momentum. This is called a Wein filter. See
http://titan.triumf.ca/equipment/beamline/wienfilter.shtml
(correct spelling is Wein). Also search web.
Also, crossed fields are used in magnetron microwave tubes, like the ones used in microwave ovens. The electrons are accelerated away from the filament by the E field, and rotate around the cavity, deflected into a circular orbit by the B field.
Bob S
Sorry for mistake.
Despite B_0 into the denominator the whole functions doesn't diverge to infinity.
I got the right limit by means of Mathematica.
Warmest Regard
Barbara
(Rome)
  • · Replies 22 ·
