| Thread Closed |
springs & circular motion |
Share Thread | Thread Tools |
| Nov7-09, 12:28 PM | #1 |
A small block is launched on the fricntionless loop the loop shown. te sprink launcher has a sprink constant k a)find the velocity at the top of the loop as a function of the displacement x of the spring launcher from its equilibrium length b)find the minimum cvalude of x such that the block goes over the top in contact with the track c)find the normal force on the bock A as a function of x 2. Relevant equations 3. The attempt at a solution I believe i would have to use .5ks2, and then calculate the acceleration, and aply it to uniform circular motion, is this correct W = .5kx2 K = .5mv2 v = (2W/m).5 = (kx2/m).5 |
| Nov8-09, 05:42 PM | #2 |
ok pretend my first attemp never happened
Part A TA = .5ks2 UA = 0 TB = .5mv2 UB = -2Rmg .5ks2 = .5mv2 - 2Rmg v = ((ks2 + 4Rmg)/m).5 Part B same as above, just solved for s s = ((mv2-4Rmg)/k).5 Part C not really sure about the Normal Force, Does it still point up even if its on the top of the loop the loop |
| Nov8-09, 10:08 PM | #3 |
Recognitions:
When the block is moving in the loop, two forces are acting. One centripetal force and the other the weight of the block. Mg*cosθ contributes to the normal reaction.
| Nov9-09, 07:47 AM | #4 |
so the normal is
N = mgcos(180) do u agree with my other responses, they do not match what the answer is said to be Part B answer is xmin = (5mgR/k)1/2 Part C answer is N(x) = (kx2/R) - 5mg where does that 5 mg come from |
| Thread Closed |
| Thread Tools | |
Similar Threads for: springs & circular motion
| Springs, motion, and friction | Advanced Physics Homework | 3 | ||
| Identifying the forces in a difficult circular / non-circular motion hybrid problem. | Introductory Physics Homework | 5 | ||
| One Mass, Two Springs, 2-D Motion | Advanced Physics Homework | 0 | ||
| Slinky springs and eq of motion. | Introductory Physics Homework | 1 | ||
| Motion in springs | Advanced Physics Homework | 1 | ||
