Help Needed: Creating MATLAB Program for Liquid Solutions
  • Thread starter Thread starter Sergiomppinto
    Matlab Program
The discussion centers on creating a MATLAB program to calculate the mixture levels of liquid solutions, specifically water and detergent, as well as water and sugar. The user seeks to measure the mixture's concentration over time and position, with values ranging from -1 (pure sugar) to 1 (pure water). Additionally, another user inquires about placing BMP images in a 3D matrix for image processing, highlighting the need for transparency in intermediate layers. Both topics emphasize the importance of MATLAB programming skills for effective implementation.
  • MATLAB programming skills
  • Understanding of liquid solution dynamics
  • Familiarity with 3D matrix manipulation in MATLAB
  • Knowledge of image processing techniques in MATLAB
  • Research MATLAB functions for simulating liquid mixtures
  • Learn about MATLAB's 3D plotting capabilities
  • Explore image processing functions in MATLAB for BMP files
  • Investigate MATLAB's handling of transparency in 3D visualizations
Students, researchers, and developers working with MATLAB who are interested in liquid dynamics simulations and image processing techniques.
Sergiomppinto
Hi i'mm needing help creating a MATLAB program to calculate liquid solutions, I'm going to try to explain the program i want,
imagine you have to 2 water solution one is water the other one is detergent, what i have to do is to create a code that will allow me to mesure the level of misture between the 2 solution being the variables the time and the position.
Another exemple, imagine you have a glass and you have a solution of water and sugar completlly dissolved, in the beginning you have a level of 0 misture, it means you have 50% sugar and 50% water, as the time goes bye the sugar starts to get on the bottom of the glass and the water (supostly without sugar on the top of the glass) so on the bottom you have a value of -1 that tells you that there is only sugar and on the top you have a value of 1 that tells you that there is only water there but as you change the position of the mesure the value changes allowing you to know if is has more sugar or water, and as the time goes bye in the same place the value also changes more positive on the top and more negative on the bottom.
Can anyone help me creating this?
(sergiomppinto@hotmail.com)
You probably won't get much help here until you show that you've made some effort at getting started on it.
Dear Sirs.,
I'm starting to work with image processing. Suppose I have a 3D matrix MMM with the following size: 41x41x21. (X- 41 points Y-41 points Z- 21 points).
I want to place on MMM(:,:,1) and on MMM(:,:,21) 2 bmp pictures. How can I do it but
more importly how do I plot MMM with the condition that MMM(:,:,2:20) is transparent.
I assume that the 2 bmp pictures are colored and MMM doesn't have to be a 3D matrix.
I'm more interested in showing the 2 pictures with a space between them.
Many Thanks
Amir Yefet
  • · Replies 28 ·
52K
11K
