| Thread Closed |
Phase portrait of nonlinear system of differential equations |
Share Thread |
| Nov7-09, 10:46 PM | #1 |
Describe the phase portrait of the nonlinear system x' = x^2, y' = y^2 Also, find the equilibrium points and describe the behaviour of the associated linearized system. 3. The attempt at a solution We have an equilibrium point at (0,0). The associated linearized system is x' = 0, y' = 0. The phase portrait for this consists of lines of equilibria along x = 0, and y = 0. For the nonlinear system, I have found solutions x(t) = -1/t and y(t) = -1/t. I don't know what these solutions mean in terms of a phase portrait. Nor can I express the solutions in terms of constants x_0 and y_0. |
| Nov8-09, 01:17 PM | #2 |
Mentor
It looks like you have left off the constant of integration when you found solutions x(t) and y(t). Both of your differential equations are separable.
dx/dt = x2 ==> dx/x2 = dt ==> [itex]\int dx/x^2 = \int dt[/itex] ==> -1/x = t + C1 ==> x = -1/(t + C1) Similarly, y = -1/(t + C2) You should be able to determine the constant from your initial conditions. In the special case where C1 = C2 = 0, the trajectories follow the line y = x. If t > 0, the solution points approach the origin along the part of the line in the third quadrant. If t < 0, the solution points approach the origin along the part of the line in the first quadrant. Different initial conditions will generate different trajectories, but I believe all of them will be straight lines pointing into the origin. Does that make sense? It has been a lot of years since I studied dynamical systems, so I might be a little off base on some of this. |
| Nov8-09, 02:40 PM | #3 |
Thanks :) It makes sense.
| Thread Closed |
Similar discussions for: Phase portrait of nonlinear system of differential equations
| clockwise or counterclockwise? (linear system phase portrait) | Calculus & Beyond Homework | 1 | ||
| numerical solutions of system of nonlinear algebraic equations nonlinear algebraic eq | General Math | 6 | ||
| system of nonlinear equations | General Math | 4 | ||
| Need help with nonlinear differential equations | Introductory Physics Homework | 7 | ||
| Nonlinear system of differential equations | Differential Equations | 1 | ||
