So, my question is, where did I go wrong in my approach?
The discussion revolves around a problem in functional analysis, specifically concerning the properties of subspaces in L² spaces. The original poster is tasked with demonstrating that the dimension of a subspace S of L²([0,1]) is constrained by a given inequality involving a constant K.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the implications of Bessel's inequality and consider the role of orthonormal bases in their reasoning. There are attempts to express functions in terms of basis vectors and to derive contradictions based on the dimension of S relative to K.
The discussion is ongoing, with participants sharing various approaches and expressing confusion about the application of Bessel's inequality. Some are questioning their understanding of the problem and the assumptions involved, while others are attempting to clarify their reasoning through different examples and scenarios.
There is mention of specific values for K and the implications of these values on the functions within the subspace S. Participants are also considering the nature of functions that could belong to S and the constraints imposed by the original problem statement.
Doom of Doom
Let S be a subspace of [tex]L^{2}(\left[0,1\right])[/tex] and suppose [tex]\left|f(x)\right|\leq K \left\| f \right\|[/tex] for all f in S.
Show that the dimension of S is at most [tex]K^{2}[/tex]
The prof hinted us to use Bessel's inequality.
Namely, let [tex]\left\{ u_1,\dots, u_m \right\}[/tex] be a set of orthonormal vectors in [tex]L^{2}(\left[0,1\right])[/tex]. Then [tex]\left\| f \right\|^2 \geq \sum_{k=1}^m \left| \left\langle f, u_k \right\rangle\right|^2[/tex]
I just keep getting stuck, and getting things like
[tex]\left\|f \right\|^2 =\int_0^1 \left|f(x)\right|^2 dx \leq \int_0^1 K^2 \left\|f \right\|^2 dx = K^2 \left\|f \right\|^2[/tex]
and I can't figure out how to apply Bessel's inequality.
I guess the goal is to assume m linear independent vectors, and show that m is less than K^2. Help, please?
haven't totally put it together yet, but I'm thinking start with assuming an orthonormal basis for S:{...,ui ...} of dimension m.
Try expanding f in terms of the basis function & then knowing both the ui and f satsify the given inequality, hopefully you can find a contradiction if m>K2 as you say
considering a function which is a certain linear combination of an orthogonal basis for S should help. As S is a subspace, its closed under linear combinations, so the function is contained in S
Still at a loss...
So: Assume {u1, ..., um} is an orthonormal basis of S.
I'm trying the function f= u1 + ... + um. Is this the right one to consider? It certainly is the nicest.
Then ||f|| = sqrt(m).
I still don't know where exactly to apply the Bessels inequality. If I do, all I keep getting is that
m^2 < m^2 K
which tells me nothing.
More help? Thanks for the response.
must be missing something.. thought it would follow on, but when i went to work it completely, went in a circle...
now I'm not even so sure i understand the question correctly, what about sinusoidal basis functions, couldn't you have an infinite orthogonal number of those with ||f|| =1, and maximum magnitude ~ sqrt(2)
will pass it on to some of the other guys to have a look
Ok, I'm started off with a different approach to see if I could understand this a bit better... and it only leads me to believe that the problem must be wrong.
Assume K=1 (since that is the smallest it can be). Then S is the set of functions on [0,1] such that |f(x)| < ||f|| for all x in [0,1]. For simplicity, let's just say that ||f|| =1.
But the integral of |f(x)|^2 from 0 to 1 must be 1, and |f(x)| can never be less than 1. Thus, it must be the case that |f(x)|=1 for all x on the interval.
So the modulus of f(x) is always 1, and thus [tex]f(x)=e^{ia(x)}[/tex] for some function a(x).
Then the inner product of f with some other function g is
[tex]\left\langle f,g\right\rangle=\int_0^1 e^{i(a(x)-b(x))}dx[/tex].
But this integral does not necessarily have to have a modulus of 1 (indeed consider a(x)=2x and b(x)=x), and thus g is not a multiple of f. This leads me to believe that there must be more than one function in the basis for S, a contradiction to the dimension of S being less than or equal to K=1.
