Angular Velocity and Angular speed ?
The discussion centers around the concepts of angular speed and angular velocity, exploring their definitions, relationships, and potential confusion arising from translations in different languages. Participants examine whether average angular speed is equivalent to average angular velocity, and the implications of these terms in various contexts.
  • Meta-discussion
  • Some participants assert that angular speed is a scalar quantity, while angular velocity is a vector quantity that includes direction.
  • One participant describes the right-hand rule as a method to determine the direction of angular velocity.
  • Another participant suggests that the formula in question may refer to the magnitude of angular velocity, which is the same as angular speed.
  • There is a discussion about the translation of terms in different languages, particularly Spanish, where "velocidad" is used for both speed and velocity, leading to potential misunderstandings.
  • One participant mentions that while average angular speed and average angular velocity are technically not the same, they may be treated as equivalent in the context of 2-dimensional objects.
  • Another participant provides a method for calculating linear velocity from angular velocity, highlighting the use of cross products and scalar equations.
Participants express differing views on whether average angular speed and average angular velocity are equivalent, indicating that the discussion remains unresolved. There is also a shared acknowledgment of translation issues, but no consensus on the implications of these terms.
Some participants note that the definitions and usage of terms may vary based on language and context, which could lead to confusion in understanding the concepts of speed and velocity.
chickens
I have a book that gives a formulae Angular Speed as same as the Angular Velocity...is that true?
From what i understand, speed is a scalar quantity...so it only have the magnitude value while velocity is a vector quantity which also shows the direction.
Also, will the average angular speed = average angular velocity? The same book states its the same...but I have doubt on that statement ...could anyone help me in this? Thanks in advance :smile:
You're right, the angular velocity should have a direction. If I recall correctly, you can use the right-hand-rule: if you curl your fingers in the direction that it's rotating and stick your thumb out, the direction of your thumb is the direction of the angular velocity. So, for example, if you're looking at a clock head on, your right hand fingers will curl clock-wise (they better if you're looking at a clock!) and your thumb will point towards the clock, through the wall, so the direction of angular velocity of the hands is through the wall.
In English you have two terms for the same thing, speed as a quantity and velocity as a vector (curiously in spanish, a language with a huge vocabulary, we use "velocidad" for that two things) and you can distinguish. Most of books which were not english original, may be bad translated. Its very frecuently...
The major part of physics books that I have are Spanish-translated, so there ary many concepts that are not very good translated, such as "speed" or "velocity" that we can't distinguish :)
Bye
MigUi:
Do you mean it doesn't exist other "velocity"-words in Spanish??
(For example: "celeridad" or something..)
Yep, I think AKG has it. The formula your book has is probably one for the magnitude of the angular velocity, which is the same as the angular speed. The direction of the angular velocity is as AKG said, using the right-hand convention, likewise the direction of the angular momentum.
Technically, they're not the same. But, if you're analyzing 2-dimensional objects (circles, ellipses, etc), you're probably better off treating them as the same.
For 2-dimensional objects lying in the fundamental plane, the angular velocity vector only has one component - and it is perpendicular to the plane of the circle/ellipse (either up or down, depending on whether the rotation is counterclockwise or clockwise).
For example, if you're trying to find linear velocity on a circle of radius r and an angular velocity w (closest I can come to little omega in text), the 'proper' way is to take the cross product of vectors w and r, or multiply the scalar value of w by the scalar value of r times the sine of the angle between the two vectors, or, knowing the sine of 90 degrees is 1, you could just use the scalar equation: radius length times angular speed (usually the most sensible way).
These is even more so in the computer science field here in Latin America. I remember reading through two database books (one translated in Mexico and the other in Spain). The word for tuple in the 'mexican' book was "tuple" while in the 'spanish' book it was "tupla". Another example is the word key which the 'mexican' book translated as "llave" and the 'spanish' book as "clave". Talk about confusing.
Speed in spanish translates to 'rapidez' while velocity is 'velocidad'. Why people decide to use only 'velocidad' is beyond me. This reminds me when I was learning german and I asked my dad (who is german) what speed is in german and he said 'Geschwindigkeit'. I later found out that he was incorrect because the proper word is 'Tempo'. I guess for the sake of simplicity people use one term to refer to both things.
Yes, but "rapidez" is not used as common as speed in english
  • · Replies 21 ·
20K
  • · Replies 48 ·
9K
  • · Replies 17 ·
