Communicating Vessels in a noninertial reference frame
The discussion centers on calculating the acceleration of a fluid in a glass tube on an accelerating cart, utilizing the law of communicating vessels and the concept of "effective vector g." The user is tasked with determining the acceleration (a) given a fluid level rise (D = 0.6 m) and a distance (L = 0.2 m) while assuming gravitational acceleration (g) is 10 m/s². The solution involves recognizing that the effective vector g is the vector sum of gravitational acceleration and the fictional gravity due to the cart's acceleration.
  • Understanding of the law of communicating vessels
  • Basic knowledge of vector addition in physics
  • Familiarity with gravitational acceleration concepts
  • Introductory physics principles, particularly in non-inertial reference frames
  • Study the law of communicating vessels in detail
  • Learn about effective gravitational forces in non-inertial frames
  • Explore vector addition and its applications in physics
  • Investigate the principle of equivalence in physics
Students beginning their studies in physics, particularly those interested in fluid dynamics and non-inertial reference frames, as well as educators seeking to clarify concepts related to acceleration and gravity.
Idoke
Hello all,
Should be a simple question (just started Physics 1 not long ago).
Here it is:
The thin, fluid filled glass tube is sitting on an accelerating cart.
As a result the level of the fluid rises as shown in the picture (attached) by D = 0.6 m.
The distance L is given. L = 0.2 m.
Acceleration due to gravity is assumed to be 10.
Question: What is the acceleration a?
I was told to use the law of communicating vessels (very little information in English is found online on this subject) and "the effective vector g" (no idea what that means).
Very flustered by this, any help or a nudge in the right direction is appreciated.
Thank you!
Welcome to PF!
Hello Idoke! Welcome to PF! :smile:
The principle of equivalence means that a body with acceleration a can be regarded as stationary if fictional "gravity" of strength a is added.
So I think the "effective vector g" is the (vector) sum of the usual g (10 m/s) and this fictional gravity of a.
Calculate the direction of this effective vector, and then pretend that gravity is in that direction, and that the cart is stationary. :wink:
Thanks a lot! that did the trick! I was getting so confused with pressures and other things.
You rock!
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 19 ·
