Finding velocity when a mass suspended from a spring passes through equilibrium
A 1kg mass suspended from a spring with a spring constant of 100 N/m is compressed by 10 cm before being released. The potential energy stored in the spring (PEelastic) is calculated using the formula PEelastic = 1/2 kx^2, resulting in 5 Joules. At the equilibrium position, this potential energy converts entirely into kinetic energy (KE), allowing the velocity of the mass to be determined using KE = 1/2 mv^2. The final velocity of the mass as it passes through the equilibrium position is 3.16 m/s.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of potential energy and kinetic energy equations
  • Basic algebra for solving equations
  • Familiarity with the concept of equilibrium in mechanical systems
  • Study the derivation of Hooke's Law and its applications in mechanics
  • Learn how to convert potential energy to kinetic energy in dynamic systems
  • Explore the principles of oscillatory motion and energy conservation
  • Investigate real-world applications of springs in engineering and physics
Students in physics, mechanical engineers, and anyone interested in understanding the dynamics of mass-spring systems and energy transformations.
MRM
A 1kg mass is suspended from a vertical spring with a spring constant of 100 N/m and the equilibrium position is noted. The spring is then pushed upward (compressed) a distance x=10 cm before the mass is released from rest. How fast will the block be moving when it passes through the equilibrium position?
PEelastic=1/2kx^2
KE=1/2mv^2
I honestly have no idea what I'm doing. I used the equation above and got: 1/2(100)(10)^2 which equals 5000, but I'm honestly not sure what to do after I get the PEelastic (or if I'm even supposed to solve for that). I think if I could figure out KE, I could solve for velocity, but I'm not sure how to solve for kinetic energy...any help in the right direction would be great...
You are going in the right direction by finding PEelastic. By doing this you also found KE since KE=PEelastic so from there you just plug it into the equation.
  • · Replies 31 ·
  • · Replies 18 ·
