Evalute expression of associated Legendre's polynomial
  • Context: Graduate
  • Thread starter Thread starter kzhu
    Expression Polynomial
This discussion focuses on evaluating the expressions of associated Legendre's polynomial, specifically the terms \(\frac{P_n^1(\cos\theta)}{\sin\theta}\) and \(\sin\theta P_n^1'(\cos\theta)\) at the angles \(\theta=0\) and \(\theta=\pi\). Two conflicting references, Harrington's "Time-Harmonic Electromagnetic Fields" and Balanis' "Advanced Electromagnetic Engineering," provide different values for these terms, both claiming correctness based on phase conventions. The resolution involves using the recursive relation of associated Legendre functions, leading to a cancellation of \(\sin\theta\) and a straightforward proof through mathematical induction.
  • Understanding of associated Legendre polynomials
  • Familiarity with recursive relations in mathematical functions
  • Knowledge of electromagnetic wave scattering principles
  • Basic proficiency in mathematical induction
  • Study the recursive relation of associated Legendre functions in detail
  • Explore phase conventions in Legendre polynomials and their implications
  • Learn about the physical significance of electromagnetic wave scattering
  • Investigate the mathematical induction techniques applied to polynomial expressions
Researchers, physicists, and engineers working in electromagnetic theory, particularly those involved in wave scattering and mathematical modeling of associated Legendre polynomials.
kzhu
Dear All,
I am implementing the scattering of dielectric sphere under electromagnetic plane wave. The expression of the field contain [tex]\frac{P_n^1(\cos\theta)}{\sin\theta}[/tex] and[tex]\sin\theta P_n^1'(\cos\theta)[/tex], where the derivative is with respect to the argument.
These two terms are giving me difficulty when [tex]\theta=0[/tex] or [tex]\theta=\pi[/tex].
When [tex]\theta=\pi[/tex], in one book (Harrington's Time-Harmonic Electromagnetic Fields), both terms are stated to be
[tex]\frac{(-1)^n n(n+1)}{2}[/tex] on Page 295. In another book (Balanis' Advanced Electromagnetic Engineering), both terms are equal [tex]-\frac{(-1)^n n(n+1)}{2}[/tex].
I don't know which one is correct. Could someone tell me how could I evaluate these two expressions at [tex]\theta=0, \pi[/tex]. Thank you.
kzhu
they are both right, depending only which phase convention do you use for the Legendre Polynomial terms.
Legendre Polynoms are defined as an orthonormal basis, a phase (as a sign) doesn't affects their physical description, try to understand the physical meaning of what are you doing in order to solve this phase problem...
Thx for the discussion.
I was able to derive these two expressions. The method is to use the recursive relation of associated legendre's function
[tex](m-n-1)P_{n+1}^m(x) + (2n+1)xP_n^m(x) - (m+n)P_{n-1}^m = 0.[/tex]
and get
[tex]\frac{P_{n+1}^1}{\sin\theta} = \frac{2n+1}{n}\cos\theta\frac{P_n^1}{\sin\theta}-\frac{n+1}{n}\frac{P_{n-1}^1}{\sin\theta}.[/tex]
which is another recursive relation. If we substitute
[tex]P_1^1(\cos\theta) =<br /> -\sin\theta[/tex][tex]P_2^1(\cos\theta)=-3\cos\theta\sin\theta[/tex], and
[tex]P_3^1(\cos\theta)=-\frac{3}{2}(5\cos^2\theta-1)\sin\theta[/tex]
the [tex]\sin\theta[/tex] will cancel out. With the recursive relation, the proof with math induction towards the expressions is straightforward. :)
I still have difficulty to map the solution with [tex]e^{j\omega t}[/tex] convention to [tex]e^{-j\omega t}[/tex] though. :(
  • · Replies 29 ·
