| Thread Closed |
Increment (or decrement) a parameter in LaTeX |
Share Thread | Thread Tools |
| Nov14-09, 11:51 PM | #1 |
How can I increment or decrement a parameter in LaTeX?
For example, suppose I create an environment foo as follows: \newenvironment{foo}[2]{\begin{tabular}{*{#1}c*{#2}r}}{\end{tabular}} I can write \begin{foo}{4}{3} <tabular data in seven columns> \end{foo} But in my application, if the first parameter is n, then second is always n-1. Is there a way to write this that passes only one parameter (in this case n), but which will produce the table with n + (n - 1) columns as in the environment foo? Decrementing the parameter #1 inside the newenvironment -- if it is possible -- would surely work, but I don't know how to do it. Note: The snippet \let\temp#1 \advance\temp by -1 doesn't work because if I pass the parameter 4, \temp takes the value 'the character 4', which can't follow the \advance command. I'm stuck. Any help? |
| Nov16-09, 04:44 PM | #2 |
This solution was posted by Joseph Wright on LaTeX Community:
"You don't want \let, you want to do things with numbers proper. The thing is that they then [need] to be assigned to TeX counters. You seem to want something like \newcount\mycount \newenvironment{foo}[1] {% \mycount #1\relax \advance\mycount -1\relax \begin{tabular}{*{#1}c*{\the\mycount}r}% } {\end{tabular}} Here, I'm using a TeX count register to do the maths. You can do the same with a LaTeX counter, but I find this route a bit easier for going downward. TeX assigns count registers locally, so the above should work in most cases." Thanks, Joseph. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Increment (or decrement) a parameter in LaTeX
| The smallest increment of time a human can percieve? | Medical Sciences | 19 | ||
| Torsional pendulum, logarithmic decrement | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Torsional Pendulum, Logarithmic Decrement | Introductory Physics Homework | 1 | ||
| increment value of equvalent resistance when the resistances are parallel | Introductory Physics Homework | 2 | ||
| Why does my post count not increment? | General Discussion | 2 | ||
