How Do I Calculate Friction Force and Mass in This Dynamics Problem?
  • Thread starter Thread starter physics_newb
    Dynamics Urgent
The problem involves dynamics, specifically calculating the friction force and mass of a fridge being pushed by two individuals with different forces and resulting accelerations. The original poster describes the scenario and provides initial calculations based on the forces applied and the resulting accelerations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using two equations derived from the forces and accelerations for each individual pushing the fridge. There is confusion about how to manipulate these equations to find the unknowns, particularly the friction force and mass.
Some participants have offered guidance on using simultaneous equations to solve for the mass and friction force. There is ongoing exploration of the calculations, with some participants expressing confusion about the units and the results obtained.
There is a mention of a lack of notes from the teacher on how to approach the problem, which contributes to the participants' confusion. The original poster also notes a time constraint, as the assignment is due soon.
physics_newb
Dynamics Problem..Grade 11 Urgent Help Needed!
Paul and Mintu are attempting to push a heavy fridge across the kitchen floor. When Paul pushes it with a muscular force of 550N, the fridge accelerates from rest to 28.0cm/s in 3.5s. When Pintu pushes it with a muscular force of 560N, the fridge accelerates from rest to 36cm/s in 3.0s. Calculate the force due to friction and mass of the fridge.
v1=0.0cm/s
v2=28.0cm/s
t=3.5s
F=550.0N
F_2=?
a=?
Paul
v1=0.0cm/s
v2=28.0cm/s
t=3.5s
F=550.0N
F_2=?
a=?
Step 1
a=(v_2-v_1)/t
a=(28-0)/3.5
a=28/3.5
a=8m/s^2
Step 2
Fnet=ma
F_net=F+F_2
ma=F+F_2
Type equation here.
That is what I've done so far but after I got to the end of that I realized mass wasn't given and now I'm totally confused as the teacher didn't give us any notes on how to deal with this! Please help me solve this I am completely confused
Thanks
You have two equations. One due to Paul and the other due to Mintu. In both the case F_2 is the same. Solve the two simultaneous equations to find m and F_2.
I'm sorry, I do not follow I realize that there are 2 equations and F2 should be the same but I do not understand how I use those 2 F1's to get F2 and mass. Would it be possbile to please explain further/more detail...I am completely clueless
can anyone please help me with this its 11pm here and this is due first thing in the morning and right now I'm clueless on how to do it
OK.
For Paul
m*a1 = 550 N + F_2 -----(1)
Fro Pintu
m*a2 = 560 N + F_2 -----(2)
You have found a1. Now find a2. Substitute these values in eq.1 aand 2. Subtract eq.2 from eq.1 and find m. Then using anyone of the equation finf F_2.
ohhh we have to use substitution to find m...and then find f2 using the rest? Thanks! I think i just kind of went mind blank there for a moment
ok I am kind of stuck again...after I got f2=-530N, the mass makes no sense...after solving it seems that mass =2.5...would it be 2.5 tonnes? kg? g? or is there something i did wrong?
Step 1 (Paul)
v1=0.0cm/s
v2=28.0cm/s
t=3.5s
F =550.0N
F_2=?
a=?
a=(v_2-v_1)/t
a=(28-0)/3.5
a=28/3.5
a=8m/s^2
Step 2 (Mintu)
v1=0.0cm/s
v2=36.0cm/s
t=3.0s
F =560.0N
F_2=?
a=?
a=(v_2-v_1)/t
a=(36-0)/0
a=36/3
a=12m/s^2
Step 3 (Substitution)
Fnet=ma
Fnet=F+F_2
m*8=550+F_2
m=(550+F_2)/8
m*12=560+F_2
m=(560+F_2)/12
Substitution
m=(560+F_2)/12→m=(550+F_2)/8
(560+F_2)/12=(550+F_2)/8
560+F_2=(550+F_2)/8*12
560+F_2*8=550+F_2*12
4480+8F_2=6600+12F_2
8F_2-12F_2=6600-4480
-4F_2=2120
F_2=-530N
Sub for equation 1
m=(550+F_2)/8
m=(550+(-530))/8
m=20/8
m=2.5
NVM I realized what i was doing wrong...i was using 8 (cm/s/s) instead of 0.08 (m/s/s)
