Continuous function / epsilon-delta
The problem involves proving the existence of a delta (\(\delta\)) for a continuous function \(h\) such that \(h(x) > 0\) when \(x\) is sufficiently close to a point \(a\) where \(h(a) > 0\). The context is centered around the concepts of continuity and the epsilon-delta definition of limits.
  • Participants discuss starting with the definition of continuity and the intermediate value theorem. There are attempts to formalize the proof using specific values for epsilon, and some participants express uncertainty about how to structure the proof formally.
Some participants suggest that the continuity of the function implies the existence of a delta that maintains positivity for \(h(x)\) near \(a\). Others are exploring how to articulate this in a formal proof, indicating a productive exchange of ideas without reaching a consensus.
Participants are working within the constraints of formal proof requirements and the definitions of continuity and limits, with some expressing confusion about how to transition from intuitive understanding to formal writing.
zeebo17
Let [tex]h: \Re \rightarrow \Re[/tex] be a continuous function such that h(a)>0 for some [tex]a \in \Re[/tex]. Prove that there exists a [tex]\delta >0[/tex] such that h(x)>0 provided that [tex]|x-a|< \delta[/tex].
Continuity of h means that there exists and [tex]\epsilon >0[/tex] such that [tex]|h(x)-h(a)| < \epsilon[/tex] provided that [tex]|x-a| < \delta[/tex]
I tried starting with the definition of continuity and perhaps the intermediate value theorem, but I haven't been able to get started.
Any suggestions on how to get started?
Thanks!
so because of the continuity of your function you know that there exists a delta greater than zero that will satisfy this. h(x) is greater than zero because you know that h(a) is greater than zero and if x is close to a the function has to stay positive. if it jumped around then it wouldn't be continuous.
Yes, that makes sense intuitively. I'm still unsure how to start writing a formal proof though.
In the definition of "limit", let [math]\epsilon= \frac{h(a)}{2}[/itex].
Ok, Would this work:
If h(x)> h(a) then h(x)>0 since h(x)>h(a)>0.
If h(x)<h(a) then h(a)-h(x) > 0. Then because h is a continuous function there exists a [tex]\delta>0[/tex] such that [tex]|x-a|< \delta[/tex] implies that [tex]|h(x)-h(a)|< \epsilon[/tex]. In this case h(a)-h(x) > 0, so [tex]0 < h(a)-h(x) < \epsilon[/tex].
If [tex]\epsilon = \frac{h(a)}{2}[/tex] then
[tex]0< h(a)-h(x)< \epsilon[/tex]
[tex]0< h(a)-h(x)< \frac{h(a)}{2}[/tex]
[tex]0< \frac{h(a)}{2}< h(x)[/tex]
and therefore h(x) is greater then zero.
  • · Replies 40 ·
  • · Replies 26 ·
