| Thread Closed |
Gas core cooling requirements |
Share Thread | Thread Tools |
| Nov17-09, 12:36 AM | #1 |
If we were able to build a gas core reactor, how much heat would need to be dissapated? I bring this up because traditional solid core reactors require lots of heat to be pumped away (do you know the exact number?) to keep the core for melting, but since a gas core is already much hotter wouldn't the amount of heat needing to be moved away from the reactor be significantly less?
| Nov17-09, 08:05 AM | #2 |
The heat removed would have to be the same unless you want your reactor walls to turn to gas too :)
| Nov17-09, 08:05 PM | #3 |
Yeah, you'll probably be removing heat at the same rate, the only difference is the operating temperature. You'll have a higher flow rate than a water cooled reactor because the specific heat of a gas is much lower.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Gas core cooling requirements
| Applying Newton's cooling equation to a pipe cooling | Classical Physics | 0 | ||
| CPU differences: quad core, dual core, etc. for CFD | Mechanical Engineering | 3 | ||
| requirements are for entering a career in physics | Academic Guidance | 3 | ||
| Requirements? | Academic Guidance | 1 | ||
| requirements | Academic Guidance | 1 | ||
