Density of Sea Water at 1000m Depth
  • Thread starter Thread starter drwma
    Density Water
The discussion revolves around determining the density of seawater at a depth of 1000 meters, where the pressure is approximately 1.0 x 10^7 pascal. The original poster provides the surface density of seawater as 1.03 x 10^3 kilograms per cubic meter and references the bulk modulus of water.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to use the bulk modulus to relate pressure changes to volume changes and subsequently to density changes. Some participants question the assumption that depth can be treated as a force, clarifying that depth is a distance and discussing hydrostatic pressure.
Participants are actively engaging in clarifying concepts related to pressure, depth, and the bulk modulus. Some guidance has been offered regarding the calculation of pressure at depth and the use of the bulk modulus to estimate density changes, with suggestions for further refinement through integration.
There is an emphasis on using the bulk modulus in the solution, and participants are navigating the constraints of assumptions about constant density and pressure in their calculations.
drwma
What the density of sea water at depth of 1000 M where the water pressure is about 1.0*10^7 pascal the density of sea water at the surface is 1.03*10^3 kilograms per cubic M?
BULK MODULUS=dP/dV/V
p=pressure
v=volume
B of water=,21*10^10 n/m^2
it is approx to the bulk of sea water
Ihave used the (1000m)depth as aforce at the bottom then A=f/p=1000/1.0*10^7=10^-4 M^2
dV=A*h=10^-4*1000=10^-1 m^3
from bulk modulus=dp/dv/v=,21*10^10=10^7/dv/v then dv/v=4,76*10^-3 then v(surface)= x then density surface=mass/v then mass = x then v depth = dv+v surface(because as account to the bulk modulus the volume smaller at the depth) then the density of the depth= mass/v depth
it right to assume that the depth is aforce?
no, depth is not a force, depth is a distance
a supported column of fluid in a gravitational field leads to a hydrostatic pressure (which has units of Force/Area)
the hydrostatic pressure in a constant gravitational field, is given by
[tex]P = \rho g h[/tex]
where h is the depth
thank you for help but g is the acceleration due gravity ?what p
can you help me mor is there another method ?but I have to use the bulk modulus in the solution I will be very grateful for your help
thank you a lot
g is the acceleration due to gravity
so, first calculate the pressure at 1000m assuming the density is constant
then assume the bulk modulus is constant with pressure & calculate the corresponding volume & density change. (similar to what you attempted previously)
This will be a pretty good approximatino to the densety change, to do any better you would have to set up an integral
  • · Replies 46 ·
14K
9K
