Proving "If a Segment is Given, Then it Has Exactly One Midpoint"
  • Context: High School
  • Thread starter Thread starter Imparcticle
The discussion revolves around the proof of the theorem: "If a segment is given, then it has exactly one midpoint." Participants explore various approaches to constructing this proof within the context of basic Euclidean geometry, addressing definitions, conditions, and mathematical reasoning involved in identifying midpoints.
  • One participant outlines a proof using points A and B as endpoints of segment AB, defining conditions for a point Q to be between A and B.
  • Another participant presents a proof that assumes two midpoints M and N of segment AB and shows they must be the same point, implying uniqueness.
  • A different participant provides a simplified explanation of the midpoint concept using a linear representation and equal distances from the midpoint to the endpoints.
  • One participant introduces the Pythagorean theorem to define the length of segment AB and suggests using induction to complete the proof.
  • There is a question raised about the difference between using the Pythagorean theorem and the midpoint formula in the proof.
  • Another participant asserts that the initial conditions for Q being between A and B are insufficient without including the requirement that AQ equals BQ.
  • A later reply clarifies that the initial proof attempt was meant to establish collinearity and positioning, not to assert that Q is the midpoint.
Participants express differing views on the sufficiency of the conditions for defining a midpoint. Some agree on the necessity of showing AQ equals BQ, while others focus on the collinearity aspect. The discussion remains unresolved regarding the best approach to proving the theorem.
Some participants note limitations in the proof attempts, such as the need for more rigorous justification of the conditions for a point to be considered a midpoint and the implications of using different mathematical approaches.
Imparcticle
How would you right a proof for this theorem: "If a segment is given, then it has exactly one midpoint"?
Please note that the numbering of the postulates (P) is based on my geometry book. Also, I'm just in 9th grade geometry, so please don't use differential equations or some other math than basic Euclidean geomtery. This will help me better understand the concept.
This is what I did so far:
Let points A and B be the end points of a line segment, AB.
By P2-3 (For any two points on a line, and a given unit of measure, there is a unique positive number called the measure of the distance between the two points) there is a defined distance between the points A and B on line segment AB
By the "definition of between", a point Q is between points A and B if and only if each of the following conditions hold.
1.) A, Q, B are collinear.
2.) AQ + BQ = AB
Condition 1: A,Q,B are collinear
By P1-1 ( Through any two points there is exactly one line) and P1-3 (There are at least two points on a line), points A, Q and B are on the same line. Therefore, by the definition of collinear (which states that points are collinear if and only if they are on the same line), A,Q and B are collinear.
Condition 2: AQ + BQ = AB, Let Q be the midpoint
Since Q is the only common point of segments AQ and BQ, then AQ and BQ both intersect at Q. Therefore, the end points are A and B. Since A, Q and B are all collinear, they form a line segment AB. Thus Q is in between points A and B in AB.
This is where I kind of get lost...
AQ + BQ = AB
Let A=2, B=8, Q=5
l 2-5 l + l 8-5 l = l 2-8 l
6=6
By the "definition of midpoint", a point Q is the midpoint of a segment AB if and only if Q is between A and B and AQ=BQ.
Does that prove Q is the midpoint? I don't think so because:
1.) I haven't shown that the arithmetic I did in an attempt to show the distances between AQ and BQ are equal to that of AB works for all cases.
2.)I'm not sure I have adequately proven that A, Q and B are on the same line.
Mathematics news on Phys.org
Here is the proof my math tutor wrote:
Let AB be a segment.
(show that AB has exactly one midpoint)
Let M and N be midpoints of AB.
Since M, N are midpoints of AB, M and N are between A and B and AM=MB. Furthermore, M, A and B are collinear and AM + MB = AB
AN + NB = AB
AM + MB = AN + NB
AM + AM = AN + AN (i.e. 2 * AN -> AM = AN
Therefore M and N are the same point.
Midpoint - Point B is the midpoint of the segment AC if it is between A and C and if AB=BC(that is, the distance from B to A is the same distance from B to C).
Simply this
A---B---C.
B is located at the midpoint. There is equal distance between A and B, as well there is equal distance from B to C. This shows that B is the midpoint of AC. You also notice that B is located halfway in between AC. AC/2 = B.
Find the midpoint of the points in cartesian coordinates: (2,4) and (-7, 8).
The Midpoint of points (2,4) and (-7, 8) would be the point in cartesian coordinates- ((-7 + 2)/2 , (8 + 4)/2) = (-5/2 , 6)
For the sake of simplicity, let [itex]AB[/itex] be a line segment on a two dimensional coordinate grid. [itex]A = (x_{1}, y_{1})[/itex] and [itex]B = (x_{2}, y_{2})[/itex]. The length [itex]l[/itex] of line segment [itex]AB[/itex] = [itex]\sqrt{(x_{2} - x_{1})^2 + (y_{2} - y_{1})^2}[/itex] by the Pythagorean theorem. A midpoint, by definition, is of half the length of the line segment, so we will define [itex]AQ[/itex] by point [itex]A[/itex] given previously and point [itex]Q = (x_{3}, y_{3})[/itex] such that the length
[tex]\sqrt{(x_{3} - x_{1})^2 + (y_{3} - y_{1})^2} = \sqrt{(x_{2} - x_{3})^2 + (y_{2} - y_{3})^2} = l/2[/tex]
Pick any numbers to fill in these values, then use induction to finish this part of the proof.
I think you adequately proved that the points are on the same line.
What is the difference between the application of the Pythagorean theorem to this proof and using the midpoint formula? I thought about using the midpoint formula but then thought against it.
You guys are just brilliant. Thanks.
Midpoint formula follows from the Pythagoream theorem. Either term would work.
"By the "definition of between", a point Q is between points A and B if and only if each of the following conditions hold.
2.) AQ + BQ = AB"
Incorrect! You must also say that |AQ|=|BQ|. The statement you wrote have no gurantee to be Q the mid-point. Find out the reason.
She knows that. That part of the proof was only meant to show that Q is colinear with A and B as well as somewhere between A and B, not necessarily that it is the midpoint.
  • · Replies 22 ·
