2nd Order Differential Equation Problem
The discussion revolves around an initial value problem involving a second-order differential equation: y'' + 2y' + 2y = 0, with specific initial conditions. Participants are exploring the maximum value of the solution y over the interval from 0 to infinity.
  • Mixed
  • Participants discuss the characteristic equation and its roots, with some attempting to derive the general solution. There are questions about finding the maximum value of the function and the methods to do so, including setting the derivative to zero.
Some participants have provided guidance on finding the maximum value by suggesting the use of derivatives, while others express uncertainty about their understanding of trigonometric functions and algebra. There is an ongoing exploration of the correct approach to the problem, with no clear consensus reached.
Participants have noted difficulties with trigonometry and algebra, which may impact their ability to solve the problem effectively. There is also mention of the pace of the course and the lack of examples provided by the instructor.
jonnejon
Let y be the solution of the initial value problem:
y'' + 2y' + 2y = 0 , y(0) = 0 , y'(0) = 5
The maximum value of y over 0 less than or equal to x less than infinity is ??.
r = -2 +/- i
I solved it:
y = c1 e^-2x cos(x) + c2 e^-2x sin(x)
y' = -2c1 e^-2x cos(x) - c1 e^-2x sin(x) - 2 c2 e^-2x sin(x) + c2 e^-2x cos(x)
y = c1 = 0
y' = -2c1 + c2 = 5 => c2 = 5
y = 5 e^-2t sin(x)
But I am terrible at trig. What is the maximum value of y? I got (x = -3pi/2 so therefore max y is 5 e^(6pi/2) but that is incorrect. I have one more attempt and don't want to lose out on this question.
Thanks.
The roots of your characteristic equation are wrong. They should be r = -1 +/- i.
Yeah, I missed that but doesn't change my answer much.
r = -1 +/- i
I solved it:
y = c1 e^-x cos(x) + c2 e^-x sin(x)
y' = -c1 e^-x cos(x) - c1 e^-x sin(x) -c2 e^-x sin(x) + c2 e^-x cos(x)
y = c1 = 0
y' = -c1 + c2 = 5 => c2 = 5
y = 5 e^-x sin(x)
But I still can't find the max value of y. Help please?
I think max of y is 5 e^(3pi/2) where x = -3pi/2. I don't want to exhaust my last attempt. Any confirmations?
How do you normally find the maximum value of a function? You probably spent the good part of a quarter or semester doing that.
I really don't know, my professor moves way to fast and doesn't give enough examples. I also completely forgot about that. If you show me how to do it instead of giving hints, I am sure I will learn it better that way. I would really appreciate that. Thanks.
And I'm sure that you will learn it better if you dig for it than if I just tell you. Crack your calculus book open and see if it has anything about finding the largest value of a function.
I am sorry, but I really don't know. I have been looking for awhile and I can't seem to find it. Did I do the differential equation correct though?
Yes, the solution of the initial value problem is y(x) = 5e-xsin(x).
Any maximum or minimum will come at an endpoint of the interval in question or at a point at which the derivative is zero. I truly hope that rings a bell with you.
Yeah, I found out that you set the derivative to zero but as I said before I am terrible at trigonmetry. So:
y'=5e^-x (cos(x)- sin(x))
0=5e^-x (cos(x)- sin(x))
5e^-x cos(x) = 5e^-x sin(x)
cos(x) = sin(x)
Whats next?
try solving for x? (dividing throughout by cos(x))
So, 0 = sin(x)/cos(x) = tan(x)? so tan (0)=0 so the max value of y is 0?
cos(x)/cos(x) does not equal 0...
what is 1/1, 5/5, pi/pi ?
Oh yeah, did the algebra wrong...
So, sinx/cosx = 1 = tanx
x=45?
so I should input the answer as:
y = 5 e^(-45) sin(45)?
x=45?
i think you need to put it in radians, but your method is correct
Yes!
I got it. Thanks Mark and Chewy. Yeah, I forgot to set my calculator back to radians, thanks for the help guys.
x=45?
There are an infinite number of solutions to the equation tan x = 1 on the interval [0, infinity). You have found only one of them. All you know is that dy/dx = 0 at x = pi/4. You don't know whether you have a maximum, minimum, or neither at this point.
Some thoughts on several of your comments...
You've mentioned a couple of times that you're terrible at trigonometry, you seem to have some trouble with algebra, and you didn't remember that the derivative of a function could be used to find the maximum and minimum values of that function. Now you are apparently in a class in differential equations, where knowledge of these areas is assumed. To be weak in all these areas is definitely not a recipe for success in differential equations.
I don't know what classes you are planning to take in the future, but you probably are going to have a much harder time of it until you can get up to speed in the areas where you are weak. I can't imagine that you are having an easy time of it in your present class.
  • · Replies 18 ·
