Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Reply
image Calculating max load of square tube (steel) Share It Thread Tools Search this Thread image
Old Nov19-09, 04:09 PM                  #1
drewjohn
drewjohn is Offline:
I'm trying to calculate the max load of a rack made of 3X3X1/4 steel tube. It is 8ft long and 4ft wide. I just want to calculate the max load (distributed load) in bending (prob for just the 8ft sides) and also in compression for the legs. i can't find the right formulas. can anyone help?
so far i have
MOI (I)=3.495 in^4
Section modulus=2.330 in^3
MOE (E)=29,000,000 psi ( i think this is correct but i'm not sure. just want to use low grade steel)
Old Nov19-09, 04:18 PM                  #2
Mech_Engineer
Mech_Engineer's Avatar
Mech_Engineer is Online:
Recognitions:
PF Contributor PF Contributor
Re: Calculating max load of square tube (steel)
You just need to calculate the bending stress in the beam. This page should set you on the right track: http://en.wikipedia.org/wiki/Bending
Old Nov19-09, 04:47 PM                  #3
drewjohn
I'm not sure if that is what i'm looking for. I need to know how much weight i can put on this rack (distributed load). i don't know if that that be yield strength or what??? i want to assume fix ends on an 8ft square tube (actually 2 8ft tubes parallel).
Old Nov20-09, 08:34 AM                  #4
minger
minger is Offline:
Recognitions:
No, that's what you're looking for. It's a textbook problem really. Calculate the maximum bending moment in your beam. Then apply the bending stress equation to find the maximum stress.
Via http://www.engineeringtoolbox.com/be...on-d_1312.html the maximum stress in a simply supported distributed loaded beam is:
LaTeX Code: <BR>\\sigma = \\frac{y q L^2}{8 I}<BR>
Where y is the perpendicular distance from the neutral axis, q is the load in force/length, L is the length of the beam, and I is the area moment of inertia of the cross section.
Be careful though, depending on the application. Yield strength is the strength assuming one cycle. If this beam is to be loaded and unloaded, then you should calculate a fatigue life, and then still use a safety factor.
Good luck,
Old Nov20-09, 08:45 AM                  #5
drewjohn
but what i want to know it q. right?
would be 1.5?
Old Nov20-09, 08:51 AM                  #6
minger
minger is Offline:
Recognitions:
Yes, find an allowable maximum stress and solve for q.
Old Dec6-09, 08:24 PM                  #7
ahmedidos
ahmedidos is Offline:
just as an addition to the topic.....don't confuse the moment of inertia given with the body moment of inerita.....this is the area moment of inertia whose unit in SI units system is bisqaure meter( m ^ 4)....the other moment of inertia of the body whose unit in the SI unit is (N.m) isn't applicable here
image image
Reply
Thread Tools
Similar Threads for: Calculating max load of square tube (steel)
Thread Thread Starter Forum Replies Last Post
Torsion in hollow rectangular steel tube franznad Mechanical Engineering 9 Dec4-09 10:11 AM
what size square mild steel pipe will support load hemeoncdoc Mechanical Engineering 4 Jun15-09 09:00 PM
Calculating the dead load (G) and live load(Q) of this tunnel - civil engineering que curious_iza Engineering, Comp Sci, & Technology 4 Mar28-09 09:13 PM
Marble spinning in steel tube Nightrider55 Introductory Physics 7 Feb26-08 09:21 AM
slenderness ratio and axial load of steel question..pls help beegcheef Mechanical Engineering 9 Jul6-06 02:09 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
