Stress and Strain/ Hooke's Law Question
The problem involves a traffic light suspended by a steel cable, requiring the calculation of the percentage increase in the cable's length due to the weight of the light. The context includes concepts of stress, strain, and Young's modulus, specifically related to materials science and mechanics.
  • Participants discuss calculating tension in the cable, stress, and the relationship between stress, strain, and Young's modulus. There are questions regarding the original poster's (OP) calculations of stress and strain, and whether the OP has correctly interpreted the problem's requirements.
The discussion is active, with participants providing guidance on calculating tension and stress. There is a recognition of potential confusion regarding the necessity of calculating absolute versus percentage change in length. Some participants express understanding of the OP's situation, while others clarify the relationship between strain and percentage increase in length.
There is mention of the given value for Young's modulus for steel, and some participants question whether the OP has misinterpreted the problem's complexity.
swifel7
A 50 kg traffic light is suspended above an intersection by a continuous steel cable. The cable has a diameter of 1.0 cm, and the light is depressed 12 degrees below the horizontal. What is the percentage increase in the length of the cable due to the mass of the traffic light?
Stress=Force/Area
Strain=Change in length/original length
Young's elastic modulus(E)=Stress/Strain
Area = (pi) x (r^2)
E for steel is 200 x 10^9
Well I found the stress and strain, but now I am lost.
Hi swifel Welcome to the board. Can you calculate the tension in the cables first? Can you then find the stress in the cable? Once you do that, do you know how stress, strain and modulus relate? Can you then determine the length change?
are you given the value for steel or did you look it up?
I think you are overreading the question and it is simple a triangle geometry question
I was given the E value for steel.
The question wants the percentage increase in the cable's length and you've found strain, which IS the percentage increase in length.
hi ideas.
where above do you see strain being calculated?
In that case you can easily find the stress (weight of light and area)
Then with E you can find strain, strain is the relative increase in length
Q_Goest said:
hi ideas.
The OP said he calculated the stress & strain. He probably had trouble calculating the absolute change in length of the cable, not realizing it wasn't necessary to calculate percentage change.
lol ... yep...
Wow, I already had the answer? Now I feel dumb, oh well. Thanks for the help guys, I really appreciate it.
  • · Replies 17 ·
  • · Replies 29 ·
