When A Mass is Falling from an Inclined Plane
The discussion revolves around a mass released from rest on an inclined plane, specifically focusing on the motion of the mass as it travels down the incline and subsequently falls to the ground. The incline is set at angles of 14 degrees and 26 degrees in different parts of the problem.
  • Mixed
  • Participants discuss the initial motion of the mass down the incline and express confusion regarding the angle the mass makes with the ground upon leaving the incline. Questions arise about whether the mass maintains the same angle during its fall and how to determine the angle of impact with the ground.
Some participants have provided hints regarding the nature of the mass's motion as a projectile after leaving the incline. There is ongoing exploration of the relationship between the mass's velocity at the edge of the incline and its subsequent trajectory.
Participants note the need for clarification on the second part of the problem, particularly regarding the mass's behavior after it leaves the inclined plane and the assumptions about its motion.
Procrastinate
A mass M is released from rest on a smooth plane inclined to the horizontal at 14 degrees. Find the time taken for the mass to travel 1m down the incline and the velocit attained at the end of that time.
I had no trouble with the first part - measuring the velocity and time for the part where it slides down the inclined plane.
However, the part where I am having trouble with is attempting to find the angle in which the mass makes with the ground and its line of motion when it completes the second part of its journey.
Anyone have any hints to do this? I drew a free body force diagram but I was really confused with the lines of motion.
Hi Procrastinate! :smile:
Sorry, I don't understand what the second part of the question is. :confused:
Is the mass leaving the plane? If so, how and why?
(if the plane just comes to and end, then the mass is simply a projectile with the initial speed you found in the first part, at the same angel as the plane)
Sorry, I think I must have looked over a part of the question and forgot to write it down.
A mass is released from rest 2m from the edge of a smooth plane inclined at 26 degrees to the horizontal. After reaching he edge of the plane, the mass falls to the floor,, 2m below.
Find the velocity and and the angle at which the mass strikes to the floor.
I just need a quick explanation of what happens when the mass is falling. Does it maintain the same angle, or does it change? Obviously, it changes because the answer is completely different angle but I just need to know how and I can complete the rest of the question. Thank you.
he he :smile:
… After reaching he edge of the plane, the mass falls to the floor,, 2m below.
It's a free-falling projectile. It starts with the same velocity that the previous part of the motion finished with. :wink:
(ignore reference to angel o:) in my previous post! :biggrin:)
  • · Replies 18 ·
  • · Replies 16 ·
