Originally Posted by aiklone1314
then may i know does process affect the material to becomes sc, hcp,bcc or fcc structure?
does sc, hcp, bcc or fcc structure exist itself in the natural or it depends on the proccesing part?
Metals have inherent crystal structure. Some of fcc or bcc and others are hcp. That is a property of the element. Alloys are more complex, but usually take the crystal structure of the predominant element. Some alloys can take two forms based on processing.
Grain size is affected by cooling rate from liquid. The more rapid the quench, the finer the grain size. Solid materials can be hot or cold worked, which causes the formation of dislocations, lines of defects in the crystal, which when the metal is annealed form new grain boundaries.
Surface finish/roughness affects the interactions with environment. A rougher surface offers more surface area for chemical interaction, e.g., corrosion, or mechanical affects, e.g. friction.
