Position as a function of speed
The discussion focuses on determining the position \( x \) of an object with mass \( m \) as a function of speed \( v \) under the influence of a constant power force \( \textbf{P} \) and air drag represented by \( \beta m v^{2} \). The key equations utilized include \( F = \frac{\textbf{P}}{v} \) and \( F = ma \), leading to the differential equation \( \frac{\textbf{P}}{mv} - \beta v^{2} = v \frac{dv}{dx} \). The solution involves manipulating this equation to express \( dx \) in terms of \( v \) and integrating to find \( x \).
  • Understanding of Newton's second law (F = ma)
  • Familiarity with power and force relationships in physics
  • Knowledge of differential equations
  • Basic integration techniques
  • Study the derivation of the relationship between power, force, and velocity in physics
  • Learn about solving first-order differential equations
  • Explore integration techniques for variable separable equations
  • Investigate the effects of drag forces on motion in fluid dynamics
Students studying classical mechanics, physics enthusiasts, and anyone interested in the mathematical modeling of motion under external forces.
Johnny Blade
There's an object with mass [tex]m[/tex] in movement in the horizontal axes. There's a force [tex]\textbf{P}[/tex] of constant power acting on the object. Another force is the air drag which has the magnitude of [tex]\beta m v^{2}[/tex]. I need to find the position [tex]x[/tex] as a function of the speed [tex]v[/tex].
[tex]\textbf{P} = \vec{F} \cdot \vec{v} = Fv[/tex] because the vectors are parallel
[tex]\Rightarrow F = \frac{\textbf{P}}{v}[/tex]
[tex]\left|\vec{f}\right| = \beta m v^{2}[/tex]
[tex]F = ma[/tex]
With these equation I plug them in [tex]F = ma[/tex] and I get [tex]\frac{\textbf{P}}{mv}-\beta v^{2}=\frac{dv}{dt}[/tex] then by multiplying by [tex]\frac{dx}{dx}[/tex] I got [tex]\frac{\textbf{P}}{mv}-\beta v^{2}=v\frac{dv}{dx}[/tex].
Then I don't know how to solve this. Or perhaps there's an easier way to this problem?
P/mv - βv^2 = v*dv/dx.
Multiply by v on both the side. You get
P/m -β*v^3 = v^2*dv/dx.
So
dx = v^2*dv/( P/m -β*v^3 )
Now find the integration to find x.
  • · Replies 27 ·
