Final Momentum & Velocity of 3kg Object after 24N Impulse
  • Thread starter Thread starter princexcharles
    Impulse
The final momentum of a 3.0 kg object, initially moving at -2 m/s, after receiving an impulse of 24 N·s is 18 kg·m/s in the negative x direction. The final velocity of the object is calculated to be 6 m/s in the same direction. The calculations confirm that the impulse increased the object's speed from 2 m/s to 6 m/s, demonstrating the principle of momentum conservation, where the total momentum before and after the impulse remains constant.
  • Understanding of impulse and momentum concepts
  • Basic knowledge of Newton's laws of motion
  • Ability to perform calculations involving mass, velocity, and impulse
  • Familiarity with the formula for momentum (P = mv)
  • Study the conservation of momentum in different collision scenarios
  • Learn about impulse-momentum theorem applications in real-world problems
  • Explore advanced topics in dynamics, such as force-time graphs
  • Investigate the effects of varying mass on momentum and velocity
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of momentum and impulse in motion.
princexcharles
ok, i get this question that says:
"An object of mass 3.0 kg is moving in the neg. x direction with a speed of 2 m/s. it is acted upon by a force with an impulse of 24 N s. What is the final momentum and the final velocity after that impulse has acted on the object? so i did
P(initial) = mv
P = 3 x -2 = 6
J = (mv)final - (mv)initial
24 = (mv)final - (-6)
18 = mv
18 = (3.0)v
v = 6 m/s
so 18 is the final momentum and 6 is the final velocity?
Yes, that's right.
Yes, your calculations are correct. The final momentum of the object would be 18 kg m/s in the negative x direction, and the final velocity would be 6 m/s in the same direction. This means that the object's speed increased from 2 m/s to 6 m/s due to the impulse of 24 N s. It is important to note that momentum is conserved in this scenario, meaning that the total momentum before and after the impulse remains the same. This is reflected in your calculation where the initial and final momentums add up to 24 kg m/s. Great job!
  • · Replies 19 ·
