| Thread Closed |
Heat Transfer question. |
Share Thread | Thread Tools |
| Nov23-09, 10:43 AM | #1 |
A 4-in.-OD pipe is used to transport liquid metals and will have an outside surface temperature of 1400 F under operating conditions. Insulation 6-in. thick and having a thermal conductivity expressed as k = 0.08(1-0.0003T) where k is in [Btu/hr*ft*F] and T is in [F], is applied to the outside surface of the pipe. (a)What thickness of insulation would be required for the outside insulation temperature to be no higher than 300 F. (b) What heat-flow rate will occur under these conditions? 2. Relevant equations q/A = k dT/dx A = 2*(pi)*r*L, Assume L is 1 ft. 3. The attempt at a solution q/A dr = k dT Integrate on both sides q/2*(pi)( ln(r-pipe)-ln(r-insulation)) = 0.08(T-0.00015T^2)(evaluate from 1400 to 300) Is this a Trick question? Do I assume that the insulation thickness is 6-in? Or is there a trick that I am missing? I would like to have help on this by Wednesday November 25th by 4PM PST. Thanks 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov24-09, 10:27 PM | #2 |
I may be able to help a bit..I had a question simmilar to this, but I've handed it in. I made and used a spreadsheet to solve it, not calculus.
With all of your given information, you can solve for the temperature of the fluid inside the pipe. (Is the thermal conductivity of the pipe neglected?) Knowing the fluid temperature and the surface temperature, with the k value for each composite could you not solve for the thickness required to limit the temp. to 300? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Heat Transfer question.
| Question about heat transfer | Classical Physics | 10 | ||
| Help please now heat transfer question | Introductory Physics Homework | 0 | ||
| Question about heat transfer... | Introductory Physics Homework | 7 | ||
| Heat transfer question. | Classical Physics | 3 | ||
| Heat transfer Question | Advanced Physics Homework | 1 | ||
