Thread Closed
Block and strut (Equilibrium)
Share Thread Thread Tools
Nov23-09, 12:55 PM   #1
Sorry, forgot to add the picture...
The system shown to the right is in equilibrium. The steel block has a mass m1 = 248 kg and the uniform rigid aluminum strut has a mass m2 = 47 kg. The strut is hinged so that it can pivot freely about it's bottom end. The angle between the left wire and the ground is Θ = 32o and the angle between the strut and the ground is φ = 49o
2. Relevant equations
torque = rFsin(theta)
3. The attempt at a solution
a) What is the tension in the vertical wire that holds the steel block? 2432.88 N
b) What is the tension in the left angled wire?
torque(hinge) = 0 = m(block)Lcos(49) + 0.5(m(strut)Lcos(49) - T2Lcos(49-32)
I got T2 = 1827.197
That seems low for where the pivot is.
Any idea were I screwed up? Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Nov23-09, 05:11 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
We can't help you because we can't see "the system shown to the right."
Nov24-09, 07:56 AM   #3
Sorry about that...forgot to add the pic.
Nov24-09, 09:50 AM   #4
Recognitions:
You need sin(49-32) in your expression, not cos(49-32). Think of it this way, if Θ = Φ, i.e. the cable is pulling in along the direction of the strut, the torque due to the tension should be zero. This is the case if you use the sine and not the cosine.
Also, be sure to multiply all masses by g to get the weights. Your expression omits g.
Thread Closed
Thread Tools
Similar Threads for: Block and strut (Equilibrium)
Thread Forum Replies
How do you work out the tension and angle of this block in equilibrium? Introductory Physics Homework 5
time to restore equilibrium on horizontal block spring system Introductory Physics Homework 1
Dynamic Equilibrium Question (block sliding on wall) Introductory Physics Homework 2
deflection of a strut General Engineering 3
metal strut strength General Discussion 9
