Is Cosh x > 1 True for All Values of x?
  • Thread starter Thread starter Jules18
The discussion revolves around the mathematical statement regarding the hyperbolic cosine function, specifically whether cosh(x) is greater than 1 for all values of x. Participants are exploring the properties and definitions of the hyperbolic cosine function.
  • Some participants express uncertainty about the truth of the statement, questioning the meaning of the question itself. Others attempt to clarify the definition of the hyperbolic cosine function and suggest using a Maclaurin series to analyze its behavior.
The discussion is ongoing, with participants providing definitions and exploring the implications of the hyperbolic cosine function. There is a mix of interpretations and attempts to clarify the mathematical concepts involved.
Participants note potential confusion regarding the parameters and definitions involved in the problem, particularly around the use of coefficients and the notation of the hyperbolic cosine function.
Jules18
True or false?
Cosh x > 1 for all x
the answer is true, and I'm not sure why. if h is a coefficient, then I'm pretty sure I can think of some values of x and h that would be < 1.
For instance, if h=1 and x=[tex]\pi[/tex]/3
What does the question even mean?
Jules18 said:
True or false?
cosh is short for hyperbolic cosine. h is not a parameter.
This function is defined as
[tex]cosh(x)~=~\frac{e^{x} + e^{-x}}{2}[/tex]
Edit: no i in exponents
You might need to write the right side of the equation above as a Maclaurin series to show that cosh(x) >= 1 for all x.
cosh x = (Exp[x] + Exp[-x])/2
jakncoke, by Exp[x] do you mean ex where e is the constant that's approx. 2.718 ?
yes.
  • · Replies 18 ·
  • · Replies 16 ·
