| Thread Closed |
Normal coordinates and frequencies of four masses connected by springs on a circle |
Share Thread | Thread Tools |
| Nov24-09, 12:41 PM | #1 |
Given the system of 4 equal masses connected by identical springs, and constrained to move on a circle, find the normal coordinates and frequencies of the masses. I'm not looking for the answer, just a push in the right direction as I'm having trouble starting. If someone could explain how this is related to the motion of springs and masses in a straight line system, it would be much appreciated. Even a vague idea would be helpful, thanks. 2. Relevant equations 3. The attempt at a solution |
| Nov24-09, 04:10 PM | #2 |
| Nov24-09, 04:14 PM | #3 |
I should note that you will actually have 4 [itex]\theta[/itex] coordinates, one for each mass. I hope I didn't introduce any confusion on that.
| Thread Closed |
| Tags |
| normal coordinates, normal frequencies, small oscillations |
| Thread Tools | |
Similar Threads for: Normal coordinates and frequencies of four masses connected by springs on a circle
| [SOLVED] Springs, Normal Modes, and Center of Mass coordinates | Advanced Physics Homework | 6 | ||
| normal frequencies of 2 pendula connected with a massless rigid rod | Advanced Physics Homework | 3 | ||
| normal modes, 2 masses, 2 springs | Introductory Physics Homework | 0 | ||
| Two Masses Connected by a Pulley | Introductory Physics Homework | 1 | ||
| Masses connected by string/rod... | Classical Physics | 3 | ||
