Thread Closed
About a monotonically decreasing f, does it exist a theorem that says...
Share Thread Thread Tools
Nov25-09, 05:33 AM   #1
I have y=2x*f(x).
f is strictly monotonically decreasing, non-negative, derivable and continuous in the close interval [0,c] with c>=1. it doesn't change its concavity in the interval, maybe beside at x=c/2. Note that 2x has the same properties but is monotonically increasing.
i've found a maximum point for y, at x=c/2, but not knowing f i was able only to demostrate that it was a local max. i want to say that it's the global max
2. The attempt at a solution
if there's a unique maximum for y in the interval [0,c], then my local max is automatically the global max
i think that is obviously true, but does it exist a theorem that says
the product of two nonnegative functions with fixed concavity, one monotonically increasing and the other decreasing in [a,b], is a function that has a single maximum point, being monotonically incresing before and monotonically decreasing after. if the max is in a or b then the new function is only increasing or decreasing
or something like that?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov25-09, 09:24 AM   #2
Recognitions:
Homework Helper Homework Help
Counterexample: f(x)=1/x. Or 1/sqrt(x). Or1/(x2)
It's true in general that if a function is continuous and has only a single critical point, which is a local max or min, then that is a global max or min. Why? Because the derivative to the left of that point must always be positive (it can only change sign at a critical point) and to the right it must be negative. Which means the function is increasing on [a,x] and decreasing on [x,b] where x is your critical point, and you can work out the details from there.
Nov25-09, 10:18 AM   #3
Thanks for the reply.
Quote by Office_Shredder View Post
Sorry but i don't understand how these are counterexample. Beside that they aren't derivable in 0, if i multiply them with 2x i obtain functions that the max is in a or b and the new function is only increasing or decreasing
Probably i failed to write that 0=<a<b<+inf
Thread Closed
Thread Tools
Similar Threads for: About a monotonically decreasing f, does it exist a theorem that says...
Thread Forum Replies
y=cosx is decreasing Precalculus Mathematics Homework 5
Integrator monotonically increasing ? R.S. Integral Calculus 1
From decreasing sequences to decreasing functions Calculus 8
Decreasing vf Introductory Physics Homework 1
Do mathematical proofs exist, of things that we are not sure exist? Math & Science Software 43
