Volume of a shape with a different trapezium at each end
  • Thread starter Thread starter oocon
    Shape Volume
The discussion focuses on calculating the volume of a prism-shaped solid with two trapeziums at each end, specifically Trapezium 1 with dimensions a = 65.5m, b = 35.5m, h = 3.5m, and Trapezium 2 with a = 53m, b = 17.5m, h = 3m, positioned 48m apart. The solution involves determining the cross-sectional area A(x) at a distance x from one end, using proportions to express the top, bottom, and height of the trapezoids. The final volume is computed using the integral formula ∫_0^{48} A(x) dx.
  • Understanding of trapezoidal geometry
  • Knowledge of integral calculus
  • Familiarity with volume calculation of solids
  • Ability to set up and evaluate definite integrals
  • Study trapezoidal volume calculations in geometry
  • Learn about setting up cross-sectional areas for solids
  • Review integral calculus techniques for volume computation
  • Explore applications of volume integrals in engineering contexts
Mathematicians, engineering students, and professionals involved in structural design or fluid dynamics who require precise volume calculations for irregular shapes.
oocon
1. Volume of a shape with a different trapezium at each end.
Trapezium 1: a(top side) = 65.5m, b = 35.5m, h = 3.5m, height above sea level = 3m. Trapezium 2: a = 53m, b = 17.5m, h = 3m, HASL = 1.6m. Trapezoids are parallel and 48m apart. Their horizontal centres are aligned (as in sections of a reservoir).
2. Need an equation
3. Need a solution!
I assume the similar corners of the two trapezoids are connected by straight lines and you want the volume of the prism shaped solid that encloses. Consider a plane parallel to the ends at a distance x from one of the ends, giving a cross section area A(x). You should be able to figure the top, bottom and height of that cross section in terms of x using proportions. Once you have its area A(x) in terms of x, the volume would be
[tex]\int_0^{48} A(x)\,dx[/tex]
  • · Replies 33 ·
  • · Replies 67 ·
38K
