Why is the action stationary for the true path in mechanics?
  • Context: Graduate
  • Thread starter Thread starter Nick R
    Least action Principle
The discussion revolves around the physical intuition behind the principle of stationary action in mechanics, specifically why the action is stationary for the true path a particle takes. Participants explore the implications of the Euler-Lagrange equation and the significance of the action functional in the context of mechanics, touching on concepts such as the Brachistochrone problem and the relationship between kinetic and potential energy.
  • One participant questions the significance of the action being stationary and seeks a deeper understanding beyond the mathematical formulation of the Euler-Lagrange equation.
  • Another participant references Richard Feynman's explanation that particles travel along different paths simultaneously, with constructive interference occurring when the times taken by adjacent paths are similar, suggesting a connection to the principle of stationary action.
  • A participant notes that minimizing the action, which has units of energy*time, is akin to minimizing the time interval of motion, relating this to the Brachistochrone problem.
  • There is a discussion about whether minimizing action could also be interpreted as maximizing potential energy, leading to a debate about the relationships between kinetic and potential energy in a conserved system.
  • One participant clarifies that the action being minimized is the difference between kinetic and potential energy (T-V) over the path, rather than maximizing or minimizing T or V individually.
  • Another participant states that the action being stationary could correspond to a minimum, maximum, or saddle point, indicating the complexity of the situation.
Participants express differing views on the interpretation of the action and its implications, with no consensus reached on the physical significance of the action being stationary or the relationships between kinetic and potential energy.
Participants express uncertainty regarding the definitions and implications of the action, as well as the relationships between kinetic and potential energy. The discussion includes various interpretations and assumptions that remain unresolved.
Nick R
What is the physically intuitive reason behind the fact that the action is stationary for the true path a particle takes?
I understand that a path that satisfies the euler-lagrange equation minimizes (or maximizes or "saddle-points") the result of the action functional.
I also understand that the euler-lagrange equation basically says F - F = 0 where F in one side is the force as it is defined (time change of momentum) and F on the other side is true simply by the mathematical definition of the potential energy (force integrated over distance).
Neither of these things explain why the quantity of action has any significance whatsoever. Is there a significance or did someone out there just make a very astute observation that this particular mathematical quantity does something under "true conditions"?
Explainations I have read of the lagrangian formulation of mechanics always simply state that the true path is that of least action and just show how the euler-lagrange equation arises from that. Sometimes they'll talk about the classic problem in calculus of variations that has to do with finding the shape of the ramp that will minimize the time taken for a marble to roll from starting point to ending point, but this appears to have no relation to the principle of least action, since most any ramp you can come up with will result in the marble going down a true, but different path. The marble could take any of those paths it has nothing to do with finding the marble's true path.
I am not sure if I fully understand your question which may be beyond my level. However I recalled something I read which might address your question. In one of his lectures, Richard Feynman explained why a particle always travel along a geodesic using the following argument (in my own wording):
The particle actually travels along different paths at the same time. When the times taken by adjacent paths are about the same, they are in phase and constructively interfere. When the times vary a lot, they tend to cancel each out. For a geodesic which is a local minimum and hence stationary, the former case applies.
I think the same argument (stationary->constructive inference of solutions) can be applied to your question.
Wai Wong
<snip>
Because the action has units of energy*time, minimization of the action is similar to minimizing the time interval over which motion occurs- the Brachistochrone problem is usually stated as a time minimization.
Why the action is defined as the integral of the Lagrangian (as opposed to the Hamiltonian, for example), I am not sure.
http://en.wikipedia.org/wiki/Action_(physics )
The Lagrangian has many good properties, one of which is (I think) that the Lagrangian represents the energy available to perform useful work.
Couldn't you also say the action has units of energy*time, so minimization of the action is similar to maximizing the potential energy over which motion occurs? (L = T - V)
But if were maximizing the potential energy, we're minimizing the kinetic energy (in a conserved system), so were minimizing the velocity, and thus maximizing the time...
Minimizing the time would likewise correspond to maximizing the kinetic energy, which increases the action...
I'm not sure what you are trying to say. The quantity being minimized is T-V (over the path), so it's not maximizing or minimizing either T or V, but of the excess T-V.
The action is stationary for the true path: it could be at a minimum, maximum or a saddlepoint.
  • · Replies 25 ·
