What is the Equilibrium Position of a Mass in a Fluid with Varying Density?
  • Thread starter Thread starter fluidistic
    Fluid
The problem involves a mass submerged in a fluid with a density that varies with depth, described by the function ρ(x) = Kx. The mass is a parallelepiped with specified dimensions and is placed in a cylindrical container filled with this liquid. The task is to determine the equilibrium position of the mass and the motion equation when displaced from equilibrium.
  • Participants discuss the applicability of Archimedes' principle given the non-constant density of the fluid. There are attempts to calculate pressure differences and forces acting on the mass, with some participants questioning the integration of pressure over depth.
Participants are actively engaging with the problem, checking assumptions about pressure calculations and buoyant forces. Some have provided guidance on integrating pressure as a function of depth, while others are clarifying their definitions and conventions regarding forces.
There is an ongoing discussion about the correct interpretation of forces acting on the mass and the conventions used for positive and negative directions in the context of buoyancy.
fluidistic
Consider a liquid whose density [tex]\rho[/tex] varies such that [tex]\rho (x)=Kx[/tex] where [tex]K[/tex] is a constant and [tex]x[/tex] is measured from the surface of the liquid. The liquid is contained into a cylinder, and the liquid height is [tex]L=\frac{2m}{AeK}[/tex].
We introduce a parallelepiped horizontally where its upper and bottom surfaces are worth [tex]A[/tex], its mass is [tex]m[/tex] and its height is [tex]2e[/tex].
Depreciate the viscosity of the liquid.
1)Determine the equilibrium position of the mass.
2)Determine the motion equation of it, if we apart it a [tex]\Delta x[/tex] from its equilibrium position.
None given.
I don't think I can apply Archimedes' principle because the fluid hasn't a constant density.
What I did was to calculate the pressure difference between the upper and bottom surfaces of the mass.
if X is the distance between the surface of the liquid and the center of mass of the parallelepiped, I get that the force acting on the upper surface is [tex]AK\int _0^{X-e}xdx=-\frac{AK}{2}(X-e)^2[/tex].
Similarly I get the force acting on the bottom surface :[tex]\frac{AK}{2}(X+e)^2[/tex].
I sum them up to get the total force due to the pressure's difference : [tex]2AKeX[/tex].
This force acts upward. However to calculate the net force on the mass, I have to add the last force : its weight : [tex]mg[/tex].
When the mass is at equilibrium, [tex]mg=2AKeX \Rightarrow X=\frac{mg}{2AKe}[/tex].
Am I right? If so, I'll try to continue alone.
You are correct here.
It is better to calculate the pressure as a function of depth from the free surface then calculate the difference between the upward and downward force. You will see that the upward (buoyant) force has two terms not just one.
Thanks for helping!
Ok, glad to know this.
Ok so I went wrong somewhere.
[tex]P=\frac{F}{A}=\rho (x)gx=Kx^2g[/tex]... or I can't even use the formula [tex]P=\rho g h[/tex]?
No. Consider a rectangular element of fluid of area A and thickness dx such that its upper face is at the free surface. What is the pressure at the bottom of the element? To find the pressure at depth x, integrate from zero to x.
[tex]P_0[/tex] : atmospheric pressure.
So the pressure at the bottom of the element is [tex]P_0+\rho gdx[/tex]. Integrating, [tex]P_0+g\int _0^h \rho (x)dx=P_0+\frac{Kgh^2}{2}=P(h)[/tex].
Correct. Now proceed to find the buoyant force.
Force=PA thus at the bottom of the mass, [tex]F=-\frac{AKg(X+e)^2}{2}[/tex] while at the top of it, [tex]F=\frac{AKg(X+e)^2}{2}[/tex], adding them up, the buoyant force is [tex]-2AKgeX[/tex], which negative sign seems good since I took the positive sense to be from the surface of the water to the bottom. Ok so in my first post I forgot the g factor and the negative sign disappeared.
Did I go wrong? I'd get [tex]mg=-2AKgeX\Rightarrow X=-\frac{m}{2AKe}[/tex], hmm yes I went wrong. I shouldn't have this negative sign at least.
I understand that e is half the height of the parallelepiped. How have you defined X?
Oh sorry, X is the depth of the center of mass of the parallelepiped.
Then at the bottom of the mass, the force is up and equal to
[tex] F_{Bot}=+\frac{AKg(X+e)^2}{2}[/tex]
and at the top the force is
[tex] F_{Top}=-\frac{AKg(X-e)^2}{2}[/tex]
What is the sum of the two which should be the buoyant force?
I get my answer but with a positive sign... how is that possible? A positive force is a force with the same direction than the x axis, namely a force pointing at the bottom of the tank.
My convention is that "up" is positive and "down" is negative. That's why the force acting at the bottom of the box is Positive and the force acting at the top is negative.
Ah ok, so we've the same result. Then I just have to equate this with mg, right?
Right, on the assumption that the entire mass is immersed in the fluid and sinks until it reaches equilibrium at some depth denoted by X.
Ok, thanks a lot for your help.:smile:
  • · Replies 22 ·
  • · Replies 21 ·
