What is the Limit of the abc-Formula as a approaches 0?
  • Context: Undergrad
  • Thread starter Thread starter suyver
    Limit
The discussion revolves around the limit of the quadratic formula as the coefficient \( a \) approaches zero in the equation \( ax^2 + bx + c = 0 \). Participants explore the implications of this limit on the solutions of the equation, considering both roots and the conditions under which they converge.
  • One participant questions the behavior of the limit \( \lim_{a\rightarrow 0}\frac{-b\pm\sqrt{b^2-4ac}}{2a} \) and notes that it appears to diverge to \(-\infty\) for one root, while the other root seems to converge to \(\frac{-c}{b}\).
  • Another participant argues that the limit does exist and provides a transformation of the expression to show that it converges to \(\frac{-c}{b}\) as \( a \) approaches zero.
  • A different participant expresses concern about the validity of multiplying by an expression that approaches \( 0/0 \) when \( a \rightarrow 0\), questioning the legitimacy of the manipulation used to derive the limit.
  • Some participants note that the behavior of the roots depends on the sign of \( b \), leading to different convergence outcomes for the two roots as \( a \) approaches zero.
  • There is acknowledgment that the expectation for both roots to converge to the same limit is not valid due to the potential negativity of \( b \), which affects the square root term.
  • Further clarification is provided that while multiplying by terms that approach zero can be problematic, under certain conditions (e.g., \( c \neq 0 \)), the manipulations can still yield valid results.
Participants express differing views on the limit's behavior, with some asserting that one root converges to \(\frac{-c}{b}\) while the other diverges, and others debating the validity of certain mathematical manipulations. The discussion remains unresolved regarding the implications of these limits and the conditions under which they hold.
Participants highlight the importance of considering the signs of \( b \) and \( c \) when evaluating the limits, as well as the assumptions made about the values of these coefficients in the context of the limit as \( a \) approaches zero.
suyver
I was wondering something that is so simple that it baffled me...
When I have the equation
[tex]a x^2+b x+c=0[/tex]
this obviously has the solutions
[tex]x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}[/tex]
And when I have the equation
[tex]b x+c=0[/tex]
this has the solution
[tex]x=\frac{-c}{b}[/tex]
My problem now is the limiting case [itex]a\rightarrow 0[/itex] in the upper situation:
[tex]\lim_{a\rightarrow 0}\frac{-b\pm\sqrt{b^2-4ac}}{2a}\rightarrow -\infty\neq\frac{-c}{b}[/tex]
So what's wrong here? Why does this limit not exist?
The limit does exist.
[tex]\frac{-b+\sqrt{b^2-4ac}}{2a}=\frac{-b+\sqrt{b^2-4ac}}{2a}\cdot \frac{-b-\sqrt{b^2-4ac}}{-b-\sqrt{b^2-4ac}}=[/tex]
[tex]\frac{b^2-(b^2-4ac)}{2a(-b-\sqrt{b^2-4ac})}=\frac{2c}{-b-\sqrt{b^2-4ac}}[/tex]
which goes to [tex]\frac{-c}{b}[/tex] when a goes to zero. The same goes for the other square root.
But for the other root, I get:
[tex]\frac{-b-\sqrt{b^2-4ac}}{2a}=\frac{-b-\sqrt{b^2-4ac}}{2a}\cdot \frac{-b+\sqrt{b^2-4ac}}{-b+\sqrt{b^2-4ac}}=[/tex]
[tex]\frac{b^2-(b^2-4ac)}{2a(-b+\sqrt{b^2-4ac})}=\frac{2c}{-b+\sqrt{b^2-4ac}}[/tex]
which seems ok... but I don't think it is! After all, I multiply by
[tex]\frac{-b+\sqrt{b^2-4ac}}{-b+\sqrt{b^2-4ac}}[/tex]
which is [itex]0/0[/itex] in the case when [itex]a\rightarrow 0[/itex], and that's not allowed
So I don't think you can do this:
[tex]x=\frac{-b\pm\sqrt{b^2-4ac}}{2a} \rightarrow \frac{2c}{-b\mp \sqrt{b^2-4ac}}[/tex]
Right?
One root goes to -c/b. The other root becomes infinite. Which is which depends on the sign of b, since the square root goes to |b| as a goes to 0.
OK, that makes sense. I had originally expected that both roots would converge to -c/b, but now that I think about it, it seems clear that the fact that b can be negative (so that I cannot just say [itex]\sqrt{b^2}=b[/itex]) will spoil this. Oh well... too bad (for what I wanted).
Well, since [tex]\frac{-b+\sqrt{b^2-4ac}}{-b+\sqrt{b^2-4ac}}[/tex]
can only be zero when [itex]ac=0[/itex] this step is perfectly valid. We may assume [itex]a\neq 0[/itex] when calculating the limit. So that leaves [itex]c\neq 0[/itex] as a restriction. Although it would still be allowed when b is negative.
Right?
This expression is correct, but you have to take cases. If b is positive, then you'll find the expression with the negative sign to converge to [itex]\frac{-c}{b}[/itex], if b is negative the expression with the positive sign converges to [itex]\frac{-c}{b}[/itex]
  • · Replies 29 ·
  • · Replies 16 ·
