Normal and Simple Subgroups in Finite Group G: Proof of Equality for K and H
  • Context: Graduate
  • Thread starter Thread starter Bleys
    Groups Normal
The discussion revolves around the relationship between two normal subgroups K and H of a finite group G, particularly whether the simplicity of the quotient groups G/K and G/H implies that H equals K. Participants explore the implications of normality and the structure of cosets in relation to these subgroups.
  • One participant proposes that if G/K and G/H are simple, it might follow that H=K, but expresses uncertainty about how to prove this.
  • Another participant questions whether G could equal H, indicating a potential simplification of the problem.
  • A clarification is made that both H and K are proper normal subgroups of G, which is crucial for the discussion.
  • Participants discuss the relationships between the quotient groups G/H, G/K, and H/K, with one participant attempting to derive a conclusion based on the structure of these cosets.
  • A later reply introduces an isomorphism (G/K)/(H/K) = G/H as a potential solution, suggesting that the normality of K in G and H in G is essential for the proof.
  • Another participant concludes that since the kernel of the map is normal in G/K and G/K is simple, it leads to the conclusion that H must equal K, while questioning the necessity of the simplicity condition for G/H.
Participants express differing views on the necessity of the simplicity condition for G/H and whether it can be relaxed. The discussion remains unresolved regarding the implications of this condition.
Participants do not fully explore the implications of normality and simplicity, and there are unresolved assumptions regarding the structure of the groups involved.
Bleys
H,K are normal subgroups of a (finite) group G, and K is also normal in H. If G/K and G/H are simple, does it follow that H=K?
I'm almost convinced it does, but I'm having trouble proving it. I mean, the cosets of H partition G and the cosets of K partition G in the same way and on top of that partition H, right? I'm not sure when to bring in normality and the fact that the quotients are simple.
What if G=H?
no, sorry, I should have included that. H and K are proper normal subgroups in G.
Okay. Now, can you describe the relationship(s) between G/H, G/K and H/K?
This is actually where I had trouble.
[tex]G/H = \left\{ H, g_{1}H, g_{2}H,... \right\}[/tex] and [tex]G/K = \left\{ K, g_{1}K, ... \right\} = \left\{ K, g_{1}K, ... \right\} \cup \left\{ K, h_{1}K, ... \right\}[/tex] for [tex]g_{i} \in G-H[/tex] and [tex]h_{j} \in H[/tex]
That last on is [tex]G/K = \left\{ K, g_{1}K, ... \right\} \cup H/K[/tex] for [tex]g_{i} \in G-H[/tex]. Then, can you say that [tex]G/H = \left\{ K, g_{1}K, ... \right\}[/tex] for [tex]g_{i} \in G-H[/tex], since the intersection of H/K and [tex]\left\{ K, g_{1}K, ... \right\}[/tex] is just the identity element, K. Then the cosets of H in G must coincide with the cosets of K in G. Thus H=K?
Or am I totally missing it. I must be, since I haven't used either normality and simple quotients...
I have to run, so I'll leave you with a quick exercise (or reminder, in case you've seen this result previously): (G/K)/(H/K) = G/H. This isomorphism pretty much solves your problem. One way to prove it is to write down an obvious map G/K -> G/H and look at its kernel.
oh alright. So the proof of the isomorphism uses normality of K in G and H in G (specifically for the map to be a group homomorphism) and the First Isomorphism Theorem. Now, the kernel of the map is normal in its domain (ie G/K), so ker = H/K is normal in G/K. But G/K is simple, so either H/K = {1} or H/K = G/K. If H/K = G/K then (G/K)/(H/K) = {1} and so G/H = {1}. But this implies G=H, which is not the case. Therefore H/K = {1}, and so H=K. Great, thanks a lot!
But one more thing. I didn't use the fact the G/H is simple. Does it mean you can relax that condition to just exclude it?
  • · Replies 19 ·
