Cosmology: Horizon of the universe
The discussion focuses on calculating the horizon of the universe under the assumption of a flat universe with matter and a cosmological constant, utilizing the Friedmann Equations. The participant derived the scale factor \( a(t) \) and identified the need for numerical integration to compute the particle horizon. Key corrections were provided regarding the scale factor's argument, specifically that it should be \( (\Omega_M - 1)^{1/2} \). Additionally, the Hubble parameter \( h \) was clarified as \( H_0 \) in units of 100 km/s/Mpc, with a specific value of approximately 70.7 km/s/Mpc when \( h = 1/\sqrt{2} \).
  • Friedmann Equations
  • Understanding of cosmological parameters (\(\Omega_M\), \(\Omega_\Lambda\))
  • Numerical integration techniques
  • Basic knowledge of Hubble's law and units
  • Learn numerical integration methods in Python using libraries like NumPy or SciPy
  • Study the Friedmann Equations in detail, particularly in "Introduction to Cosmology" by Ryden
  • Explore the implications of different values of \(\Omega_M\) and \(\Omega_\Lambda\) on cosmic expansion
  • Investigate the relationship between the Hubble constant and cosmic distances
Astronomy students, cosmologists, and physicists interested in the dynamics of the universe and the mathematical modeling of cosmic structures.
rabbit44
This is what the question says exactly:
Assume the universe today is flat with both matter and a cosmological constant but no radiation. Compute the horizon of the Universe as a function of [tex]\Omega[/tex]M and sketch it. (You will need a computer or calculator to do this).
Friedmann Equations
So I took the Friedmann Equation with k and the radiation density as 0 and solved it to find a(t). I got:
a = [tex](\frac{\Omega_{\Lambda}}{\Omega_{M0}})^{-1/3}[/tex][tex][sin(\frac{3H_{0}(\Omega_{M0})^{1/2}t}{2}[/tex]]2/3
Latex takes ages so I don't really want to go through how I got there, but I'm pretty sure of it. Then I assumed the question is talking about the particle horizon rather than the event horizon. Either way I need to integrate 1 over this wrt t. Is this analytically possible, or is this the bit where I need a computer? The next part of the question asks me for the current horizon size if [tex]\Omega_{M0}[/tex] = 1/3 and h=1/[tex]\sqrt{2}[/tex], where I think h is something to do with H0. Just in case that next part is a clue to what I need to do.
Thanks for any help people!
Your on the right track. Though your scale factor seems to have one error in it: the [itex]\Omega_M^{1/2}[/itex] in the argument for sin should actually be [itex](\Omega_M-1)^{1/2}[/itex]. (check out equation 6.26 in "Introduction to Cosmology" by Ryden)
Yes, just integrate over 1/a times the speed of light to get the particle horizon. It does look like doing a numerical integral on a computer would be easiest.
On the second part of the problem, the parameter h is the Hubble constant in units of 100 km/s/Mpc. So if h = 1/sqrt(2) then that means that H_0 ~ 70.7 km/s/Mpc.
