Projectile Motion: explaining why Vi=Vf
The discussion revolves around demonstrating that the initial velocity (Vi) equals the final velocity (Vf) in projectile motion, particularly when the object returns to the same height from which it was launched. The subject area is primarily kinematics within the context of projectile motion.
  • Participants explore the relationship between horizontal and vertical components of velocity, questioning how to express this relationship using variables. Some suggest that the time taken to ascend is equal to the time taken to descend, while others mention the role of gravity and kinematic equations in this context.
The discussion is ongoing, with participants offering various approaches to illustrate the relationship between Vi and Vf. Some guidance has been provided regarding the use of kinematic equations and the concept of time symmetry in projectile motion.
There is a mention of needing to clarify why the horizontal component of velocity (Vx) remains constant, as well as assumptions about the initial and final heights being the same. Participants are also considering the implications of forces acting on the projectile.
shocklightnin
How can i show that vi=vf in projectile motion using variables?
Could i just say that since its a parabola we know that vx isn't going to change, but that vy is because it is affected by gravity. so when it reaches max. height, and vy=0, you know that half of the flight is done, and that the object will follow the opposite path it took to get up there, to go back downwards resulting in the same velocity since gravity and vx is constant.
except i don't know how to show this using variables..
you may have to answer why Vx does not change... any forces?
And you could use one of your kinematic equations to show that in the vertical that Vyo is equal to - Vyf when in free fall and assuming the change in position in the vertical is equal to zero.
Welcome to PF!
Hi shocklightnin! Welcome to PF! :smile:
(I assume you mean for the initial and final heights being the same?)
One of the standard constant acceleration equations will do it. :wink:
You could show that the time needed for the mass to get up to height "h" is the same time it takes for the mass to get from height "h" to the ground. Then using this time calculate Vf, and it will = Vi.
  • · Replies 23 ·
  • · Replies 22 ·
28K
