Fluid flow question using bernoulli's and continuity equations
The problem involves fluid dynamics, specifically applying Bernoulli's equation and the continuity equation to determine the diameter of a constricted section of a horizontal pipe. The scenario includes given pressures and flow rates, with an emphasis on laminar, nonviscous flow conditions.
  • The original poster attempts to apply Bernoulli's equation and the continuity equation to find the diameter of the constricted section. Some participants question the interpretation of flow rate versus velocity, and others suggest methods for converting volume flow rate from L/s to m/s.
The discussion is ongoing, with participants exploring the correct interpretation of the flow rate and seeking clarification on conversion methods. There is no explicit consensus yet, but guidance on understanding the relationship between volume flow rate and velocity has been initiated.
Participants are working under the assumption of laminar flow and nonviscous conditions, and there is a noted confusion regarding the units of flow rate provided in the problem statement.
lilmul123
The pressure in a section of horizontal pipe with a diameter of 2.0 cm is 140 kPa. Water flows through the pipe at 2.80 L/s. Assume laminar nonviscous flow. If the pressure at a certain point is to be reduced to 102 kPa by constricting a section of the pipe, what should the diameter of the constricted section be in cm?
Bernoulli's equation for constant elevation: P1 + .5p(v1)^2 = P2 + .5p(v2)^2
P1 = 140000 Pa
p = 1000 kg/m^3
v1 = 2.8 L/s
P2 = 102000 Pa
v2 = ?
Continuity equation = A1*v1 - A2*v2 = 0
A1 = pi(.01)^2
v1 = 2.8 L/s
A2 = pi(r)^2
v2 = answer to Bernoulli equation above (63.21392252 L/s)
I plugged in all known variables to Bernoulli's equation above, and got 63.21392252 L/s for the v2 flow speed. I then used the continuity equation to search for A2, and then to find r, and then to convert to d. I found r to be .0021046149 m, doubled that to find d to be .0042092298m, and converted to cm to find the final answer to be 0.42092298 cm. This is incorrect. Can someone see where I might have done something wrong? Maybe it's a simple math error?
But the quantity given in L/s is a volume flow rate, not a velocity.
Oh, of course. I just googled it, but I can't figure out how to convert from L/s to m/s, can you help me with that?
If you have a cylindrical volume representing the amount of fluid to "flow by" in one second, and you know its cross sectional area, then you know the what the third dimension (the length of the cylinder) has to be in order for the cylinder to be of that volume. Therefore, you know how much distance is covered by the fluid in one second.
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 61 ·
